Old 03-15-2016, 09:10 AM   #1
iostrym
iostrym began at the beginning.
Device: kobo
Question Use covert generated by calibre in my KOBO glo
Using calibre I am able to generate a covert based on the title and the author of the epub.
But I don't succeed to use this covert in my kobo glo.
It seems that kobo glo always use the first "page" of the epub document as a cover.
is it configurable ?
iostrym is offline   Reply With Quote
Old 03-15-2016, 09:34 AM   #2
davidfor
Yes, the Kobo devices use the first page of the book as the cover image. The first time a cover image is needed, the device renders the first page. Strictly, there isn't a way to change this. Personally, I just add the cover to the start of the book. The simplest way to do this is using the Polish books.
But, you can configure the driver to send the cover with the book to the device. With this, calibre will send whatever cover is in the library to the device with the book. For books already on the device, you can use my Kobo Utilities plugin to send just the covers.
Old 03-16-2016, 07:31 PM   #3
iostrym
Device: kobo
thanks for your answer.
so kobo don't read the cover that could be stored in the epub.
but kobo generates a cover the first time for epub from the first page. and there is a way to update the cover generated by kobo and to replace it by the one generated by calibre. right ? => ok understood and done correctly with kobo utilities. I also configured the kobo driver in calibre to have cover sent for futur book.
concerning the way to add a cover on the first page, what do you mean by : "The simplest way to do this is using the Polish books".... polish books ??
Old 03-16-2016, 08:11 PM   #4
davidfor
Yes to all that. But, there is one added twist. A few cover images are cached in memory. If you replace the cover image, you might not see it displayed until it is either removed from the cache or the device is restarted. The latter is usually the quickest way if you replace the cover for the book you are currently reading.
"Polish books" is a function in calibre to make some changes in the book in the library without doing a full conversion. The toolbar button for it looks like a brush. When you press the button, a dialog with several options is displayed. One is to add or change the cover. If the Polish books button isn't on your toolbar or menu, you will need to go into the preferences and add it.
Old 03-17-2016, 06:04 PM   #5
iostrym
Device: kobo
Thanks a lot for your help ! it works perfectly ! and you are right, some cover take a little time to be displayed in kobo.
Convert into Calibre stalifero Conversion 17 04-24-2016 10:21 AM
Kobo Glo - Series Info From Calibre to Kobo Chris_Snow Library Management 8 12-10-2015 08:11 AM
Glo Kobo glo and calibre 1.25.0 : kobo database version not suported ? gperrot Kobo Reader 2 07-13-2014 11:24 AM
Calibre doesn't covert my .rtf: why? dotofink Conversion 9 08-13-2013 04:07 PM
Glo Kobo Glo and Calibre tkavan Kobo Reader 11 05-27-2013 03:37 PM
