Old 08-11-2021, 08:35 AM   #1
harrisontate
harrisontate began at the beginning.
Question Calibre saving pdfs to disk as opfs
Hello! I apologize if this has already been posted, i couldn't find it in my search.
I have calibre on my main computer and it works perfectly, so i also downloaded it onto my laptop. I noticed though that when i convert books to pdf, it says it was successful and has the added file format of pdf. But when i save it to disk it always saves it as a opf. I thought maybe it could still work but the file is mostly just data from the conversion it seems like. I think i must be doing something wrong, but i'm not sure what specifically. I am attaching screenshots, of the book in calibre, the book in my documents after saving to disk, and the view of the opf document using google drive since i couldn't find an app that could read it on my computer.
Name:	Screenshot (162).png
Name:	Screenshot (163).png
Name:	Screenshot (165).png
harrisontate is offline   Reply With Quote
Old 08-11-2021, 11:20 AM   #2
That OPF is the Backup of the Calibre Metadata (as entered).
The cover is what you see in CALIBRE
It looks like your Conversion might have failed as there is NO PDF in that folder.
?? Can you View the HTML with Calibres viewer (simply tap 'V' with the book selected)??
Old 08-11-2021, 06:13 PM   #3
@harrisontate - could you also you post screenshots of:
1. what is in the library book folder - press 'O' to open it.
2. what you have in the Preferences->Saving books to disk settings
Old 08-12-2021, 10:37 AM   #4
harrisontate
No problem, thanks for the help. I'll post in order the view of the HTML file view, the library book folder, and preferences -> Saving books to disk. When I press v to view it takes me to a pdf web view. I even tried downloading it from the web view but it saves it as a "html document (.pdf)" and apparently can't work as a file for devices that read pdfs like kindle.
The attachments are below:
Name:	Screenshot (166).jpg
Name:	Screenshot (167).png
Name:	Screenshot (170).png
Name:	Screenshot (171).png
Old 08-12-2021, 10:50 AM   #5
Save To Disc is for EXTERNAL (to Calibre) saves.
Add Books is how you copy a download INTO Calibre
Note: Some books are delivered DRM infested. Apprentice Alf is your friend (MR rules prevent us from further help in removing that blight)
Old 08-12-2021, 11:18 AM   #6
Is there a chance that when you click on the download icon for the pdf, that Vivaldi is saving it as a .pdf.html? If so, what happens when you rename it to filename.pdf? I seem to remember other web browsers doing similar idiocies in the past.
Old 08-12-2021, 06:38 PM   #7
@harrisontate - the first image in the first post only shows PDF (conversion output), I would also expect to see the format you converted - e.g. if you bought it at Amozon, one of the proprietary Kindle formats.
You might want to try replacing the Vivaldi web browser as the default PDF reader with a something like Foxit or pdf xChange.
Old 08-15-2021, 03:24 PM   #8
harrisontate
ah i see, so do you need a screenshot of anything related to adding books settings to see if im doing something wrong there?
Old 08-15-2021, 03:26 PM   #9
harrisontate
I checked that again and when i save it it saves it as a .pdf only. For some reason once I go to the download itself in my files is when it appears as the .pdf.html even though i didn't save it as that when i can choose how to "save as"
Old 08-15-2021, 03:29 PM   #10
harrisontate
usually each file is an epub file that was sent to me or that i downloaded online. I just tend to prefer pdf format even though these books do work with epub readers that i have downloaded. So I don't think it could be a drm issue since any epub reader can read them, but maybe that still is the issue. It's confusing to understand what i need to do since the app on a previous computer worked perfectly but calibre on my new computer seems to be having issues transferring to pdf format. If you'd like I can show the epub file or show other conversion issues with my other epub files if that would help.
Old 08-15-2021, 07:20 PM   #11
Are the Save To Disk settings on the Lenovo the same as they are on your 'main computer' - if not, why not?
I'm suspicious of the 'all' the "File formats to save" field. I have it blank, and a save to disk action will save all formats I have for a book.
FWIW I would suggest your settings should be something like this:
Name:	Screenshot 2021-08-16 090316.jpg
Calibre Freezing with Adding Books and Saving to Disk jamesgl Calibre 49 01-05-2015 04:01 PM
Saving to disk fails in calibre 1.42 DrChiper Calibre 5 07-03-2014 02:44 AM
Calibre 1.25.0 Error Saving to Disk diazlaz Calibre 4 02-28-2014 10:42 AM
Saving to Disk From Calibre mitch13 Library Management 7 11-14-2013 11:54 PM
