#256 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 103
Device: Kindle Paperwhite
Patch to import collections from KFX ebooks
Hi NiLuJe,
attached to this post there is a small patch to use Kindle Collections (v1.17.19) to import the collections also for the KFX ebooks. Collections are exported using LibrarianSync In Calibre Library I added a KFX ebook (ex "book1.kfx") using one of these two options: 1 - KFX Import plug-in (by jhowell) 2 - Adding the book1.azw3 downloaded from my Amazon account and after using "match to books" from device to link book1.kfx to book1.azw3. Consider that I am a very newby with Python... Each of my changes to your code is enclosed between "# SS START" and "# SS END". Obviously, feel you free to update my "code" as you want Stefano |
#257 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 13,507
@stefano.sb: Thanks!
I tweaked it a bit, but haven't had time to test it yet. Does that behave okay?. |
| Advert | |
#258 | |
my "home made" version works ok on my Calibre. I have seen that in your tweaks (15278, 15279, 15280) you have updated only these three files. ebook.py kindle_device.py kindle_books.py Is it correct? I ran 1.7.19 version with these 3 update but it doesn't work.. Surely I'm wrong something ![]() Stefano |
#259 |
@stefano.sb: I haven't yet had the chance to test it, so, no, it's entirely possible I messed it up
#260 |
@stefano.sb: It was indeed broken
.Does this work properly? It appears to parse stuff properly, but I'm not in position to test the whole linking shenanigan and/or KFX conversions myself, so I may have missed something... On the upside, I found a massive oversight that basically made the filtering of unsupported formats useless, so, yay. Last edited by NiLuJe; 07-31-2018 at 12:19 PM. Reason: -> 1.7.20 |
| Advert | |
#261 | |
![]() I tested it also with a new kfx ebook downloaded from Amazon and imported into Calibre with "KFX input" plug-in Stefano |
#262 |
@stefano.sb: Fantastic! I'll push a new release, then
. Thank you!EDIT: Done, 1.7.20 is out .
#263 |
![]() Posts: 319
Device: Kindle Paperwhite 4 (2018)
does the initial import 'import kindle collections into calibre' take a long time? trying to decide whether or not its frozen.
latest version of plugin / 3.27.1 calibre / paperwhite v2 oh finally got an error: calibre, version 3.27.1 ERROR: Unhandled exception: <b>TypeError</b>:unhashable type: 'list' calibre 3.27.1 embedded-python: True is64bit: True Darwin-17.7.0-x86_64-i386-64bit Darwin ('64bit', '') ('Darwin', '17.7.0', 'Darwin Kernel Version 17.7.0: Thu Jun 21 22:53:14 PDT 2018; root:xnu-4570.71.2~1/RELEASE_X86_64') Python 2.7.12 OSX: ('10.13.6', ('', '', ''), 'x86_64') Interface language: None Successfully initialized third party plugins: Gather KFX-ZIP (from KFX Input) (1, 7, 0) && DeDRM (6, 5, 4) && Package KFX (from KFX Input) (1, 7, 0) && Set KFX metadata (from KFX Output) (1, 22, 0) && KFX Output (1, 22, 0) && Manage Series (1, 2, 8) && Find Duplicates (1, 6, 3) && KFX metadata reader (from KFX Input) (1, 7, 0) && KFX Input (1, 7, 0) && Quality Check (1, 9, 11) && Prettify Cover 0.9.12 && Annotations (1, 8, 0) && Count Pages (1, 8, 2) && X-Ray Creator (3, 1, 2) && Hyphenate This! (0, 0, 8) && Extract ISBN (1, 4, 4) && APNX Generator (1, 1, 0) && Goodreads (1, 1, 14) && Reading List (1, 6, 6) && Kindle Collections (1, 7, 20) && Barnes & Noble (1, 2, 15) && Modify ePub (1, 3, 13) && Goodreads Sync (1, 12, 0) Traceback (most recent call last): File "calibre_plugins.kindle_collections.ui", line 173, in import_kindle_collections File "calibre_plugins.kindle_collections.import_collect ions", line 59, in run File "calibre_plugins.kindle_collections.kindle_boo ks", line 37, in init File "calibre_plugins.kindle_collections.kindle_boo ks", line 60, in __init__ File "calibre_plugins.kindle_collections.kindle_boo ks", line 358, in load_kindle_books TypeError: unhashable type: 'list' |
#264 |
![]() Posts: 319
also running into this when trying to create kindle collections:
unhashable type: 'list' Traceback (most recent call last): File "site-packages/calibre/gui2/device.py", line 87, in run File "calibre_plugins.kindle_collections.create_preview ", line 67, in create File "calibre_plugins.kindle_collections.kindle_boo ks", line 37, in init File "calibre_plugins.kindle_collections.kindle_boo ks", line 60, in __init__ File "calibre_plugins.kindle_collections.kindle_boo ks", line 358, in load_kindle_books TypeError: unhashable type: 'list' |
#265 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 168
Device: In the house, 3 K3 in use, 4 more in storage, and a K5 for testing
Kindle Collections plug-in error
Having broken the screen on my Kindle-3-keyboard, and until a spare arrives from Distant China, I have:
-Connected the K3 to my Linux desktop machine, and copied everything from /media/Kindle to a temporary directory. -Disconnected the broken K3, and connected the spare. -Deleted everything on the spare K3 -Copied everything from the temp directory to the spare K3. Collections would not display, so I dug a bit on the forum, restarted the K3 and Bingo!, the collections work. While I was connected, I tried to use the Collections plug-in to put a few things in order and got an error message: Code:
ERROR: Unhandled exception: <b>AttributeError</b>:'BookList' object has no attribute 'rebuild_collections'
Linux-3.16.0-5-amd64-x86_64-with-debian-7.11 Linux ('64bit', 'ELF')
('Linux', '3.16.0-5-amd64', '#1 SMP Debian 3.16.51-3+deb8u1 (2018-01-08)')
Python 2.7.12
Linux: ('debian', '7.11', '')
Interface language: en_GB
File "site-packages/calibre/gui2/actions/edit_collections.py", line 38, in edit_collections
File "site-packages/calibre/gui2/actions/edit_metadata.py", line 725, in edit_device_collections
File "site-packages/calibre/gui2/device.py", line 1608, in upload_collections
File "site-packages/calibre/gui2/device.py", line 551, in upload_collections
AttributeError: 'BookList' object has no attribute 'rebuild_collections'
Before all this, the plug-in worked on the (now-)broken K3. Any idea ? Calibre 3.27.1 Collections plugin 1.7.20 |
#266 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 45,829
you should post in the thread for that plugin, there it is more likely to get attention
#267 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 22,127
#268 |
@arooni: That looks like a genuine bug, will look into it
.@rolgiati: AFAICT, that's from the vanilla Collections handling in the Kindle driver, not this plugin (and that's basically useless and/or very very limited), and it's basically unmaintained, so I can't really tell you much about it. If that's actually somehow triggered by the plugin, I'm going to have to know what exactly you were attempting to do, because I can't see it from that stacktrace .
#269 |
Released 1.7.21, which should fix @arooni's issue (you'll need to delete the plugin's on-device cache (kindle_collections_path_cache.calibre at the device's root), though).
#270 |
| Tags |
| collections plug-in, kindle |
| Kindle Collections plugin | JosephWebber | Plugins | 1 | 08-21-2017 12:44 PM |
| [GUI Plugin] Kindle Collections (old) | meme | Plugins | 2070 | 08-11-2014 01:02 AM |
| KIndle collections Calibre plugin | atp | Library Management | 0 | 02-21-2012 08:26 PM |
| [GUI Plugin] WebOS Kindle-Import | CranstD | Plugins | 0 | 01-24-2012 04:36 PM |
| [GUI Plugin] Plugin Updater **Deprecated** | kiwidude | Plugins | 159 | 06-19-2011 01:27 PM |
