Go Back   MobileRead Forums > E-Book Formats > Kindle Formats
Old 03-01-2018, 10:24 AM   #1
justerman
justerman began at the beginning.
Device: kindle PW 2013
can I format horizontal rules?
I'm creating a book that includes horizontal rules (i.e. the <hr> tag). The rules are visible in my book but they are faint and I'd like to make them more noticeable.
I've tried adding the following to the style sheet:
hr {height: 10px;}
but the formating seems to be ignored.
So my question is: has anyone succeeded in formatting horizontal rules in a kindle book, and if so, how?
justerman is offline   Reply With Quote
Old 03-01-2018, 12:26 PM   #2
tomsem
You might embed an image.
Old 03-01-2018, 01:44 PM   #3
PoP
 curly᷂͓̫̙᷊̥̮̾ͯͤͭͬͦͨ ʎʌɹnɔ
PoP's Avatar
Device: K3₃.₄.₃ PW3&4₅.₁₃.₃
In my Nadsat dictionary I use
        <style>
           hr {
                 border: white;
                 background-color: #992211;
                 height: 6px
        </style>
and it works fine.
Old 03-01-2018, 03:03 PM   #4
HarryT
HarryT's Avatar
Moved to the Kindle Formats forum.
Old 03-02-2018, 02:01 AM   #5
GrannyGrump
Obsessively Dedicated...
GrannyGrump's Avatar
It probably depends on which format you are using.
If you are converting from epub to AZW3, yes you should be able to format your <hr> to be thicker (I have used as much as 8 pt.)
But if you are converting to OLD Mobi, I think that will not honor any such styling. Anyway, when I ran a test conversion, my fat 6-pt <hr> turned out very anorexic, looking only like 1 pixel.
You might try putting a second <hr> underneath the first so you have a very widely-spaced double line. Otherwise, for old Mobi, as Tomsem suggests, an image might be your best option.
Old 03-02-2018, 06:04 AM   #6
justerman
Works fine for me too. Thany you PoP.
Old 03-02-2018, 06:12 AM   #7
justerman
I’m using kindlegen to convert from html to .mobi (I assume old mobi in your terms), then I email the doc for Amazon to convert
PoP’s code works fine for me. I don’t know why mine was deficient
Thanks for responding.
Old 03-02-2018, 08:03 AM   #8
RbnJrg
Device: Kindle 4 NT
If you are going to work with .kf8 (not the old .mobi format) then don't use <hr> tags but "borders" since you can do whatever by styling borders. For example, watch the borders I employed in the following screenshots of a .kf8 ebook:
ID:	162582 Click image for larger version
You can do something like that by reducing the height of <hx>, <div> or <p> tag to 2 or 3px and then to style the upper and bottom border as you wish. Of course, all that only works with .kf8 (not old .mobi).
Regards
Rubén
RbnJrg is online now   Reply With Quote
Old 03-04-2018, 03:54 PM   #9
justerman
Thanks GrannyGrump. I do produce a .azw3, and PoP’s style has worked for me.
Old 03-07-2018, 11:33 PM   #10
Hitch
Bookmaker & Cat Slave
Hitch's Avatar
Attachment 162582 Attachment 162583
Regards
Rubén
Rubén:
I would also mention that from time to time, we've seen border coding backfire in the iOS devices. I don't remember all of it, right off the top of my head, but...it seems to me that it's the one area, in iOS, where it's almost like you're still dealing with KF7, rather than the updated KF8 that iOS now displays pretty well.
Offered solely FWIW...if someone comes along and has an issue, they'll know that they're not the only one.
Hitch
Old 03-08-2018, 10:04 AM   #11
RbnJrg
Device: Kindle 4 NT
Rubén:
Hitch
Hi Hitch;
It's good to be aware of what you said. Particularly, I didn't know about that "border behaviour" with Kindle under iOS. It's also very good to have an expert in Kindle like you in this forum since we can always learn something new.
Regards
Rubén
Old 03-09-2018, 03:21 PM   #12
Hitch
Hitch's Avatar
Hi Hitch;
Regards
Rubén
Aw, c'mon...I just see a lot of stuff. I'm no expert. Seriously. These days, I mostly push paper and answer the phones, LOL!
But thanks for the kind words.
Hitch
Old 03-09-2018, 04:41 PM   #13
RbnJrg
Device: Kindle 4 NT
Hitch
Perhaps the words were kind but it does not stop being true
ePub to MOBI - losing horizontal rules StueyNZ Conversion 1 04-26-2012 07:09 PM
How do I centre a horizontal rule? AlexBell ePub 12 10-06-2010 04:09 AM
keep the original design (horizontal) ntrophy666 Calibre 1 01-02-2010 08:44 AM
Help! Problem with Horizontal orientation leif Sony Reader 2 09-15-2008 04:25 AM
Horizontal white line DrMoze Sony Reader 5 01-14-2008 11:57 AM
