#2566 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 408
Device: Kindle Oasis 2
@Jimm I sent you a PM, thanks for taking a look!
@Ryune that's a limitation of the e-reader software running on all Kindles, not your specific Kindle, no. I think one _should_ be able to click onto the table and then drag it around, but that feature has never worked properly for me for some reason. |
#2567 |
Plugin Developer
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 7,039
@Ryune - I believe cryzed is correct, but I confess I don't see tables inside stories very often (or ever really).
You might try converting to AZW3 instead of MOBI. It's a much newer format and may work better. |
#2568 |
![]() Posts: 13
Device: iphone 4
@ryune
There is a way of getting rid of tables in Calibre when you convert the format, however it strings the table out and can run stuff together. You could try it if you'd like. See if it's an acceptable option. In the convert dialog go to. Look and feel > layout > linearize tables. I think. I'm out right now and typing his on my phone so I cannot check. I'll probably forget to do it later. |
#2569 | ||
![]() Posts: 10
Device: Galaxy J7
I've just run into an issue with the most recent update of this plugin. Or maybe the most recent update of Calibre, as I updated both the program and the plugin at the same time. But since then, for the last couple days, I haven't been able to download or update any stories. I exclusively read off AO3, if that matters, and every time i try to use FFF to download any story, it gives me this message:
#2570 |
Plugin Developer
Sounds like the expired SSL cert issue. See FAQ:
https://github.com/JimmXinu/FanFicFa...e-errors--help Let me know if that doesn't do it. |
#2571 | |
![]() Posts: 10
Device: Galaxy J7
#2572 |
Plugin Developer
I dunno. Try it and find out.
![]() I would expect once per site to be sufficient. If it isn't, it might help to restart Calibre or even reboot windows. |
#2573 |
Plugin Developer
New test version posted
2017-12-20 - Handle QQ threads w/o threadmarks correctly. - Additional CLI python version checking. - fimfiction adapter: add new tag types, fix groups (#259), thanks FaceDeer! |
#2574 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,327
#2575 |
Plugin Developer
#2576 |
We discussed what to do about this author at a much earlier date.
Author: https://www.fanfiction.net/u/439186/SivanShemesh If I don't use the author's image from FF.net as cover for the stories, I can use this in every library? Code:
skip_author_cover: false |
#2577 | |
Plugin Developer
You may put the code: Code:
#2578 |
Thanks, I had read it as the opposite.
Merry Christmas and thanks for a fantastic plugin and you patience. |
#2579 |
![]() Posts: 36
Device: PRS-950, IPhone, Oasis 2
Right, so, just realized that I forgot to actually give my review of the Kindle Oasis 2 with FanFicFare.
So, it works rather well all things considered. Kindle has a little progress bar that is really nice when tracking your progress in a given story. When you update a story through FFF this progress bar is reset to 0% however your reading location is preserved and a 0% progress is not normally displayed unless you opened a book and left immediately. The bad part of this though is that actually finding books requires you know what you are looking for off the top of your head. The "recent" order you only get newly uploaded items and items you have recently read. Not recently updated items. So you will probably be best served by putting anything that updates into a collection for ease of discovery. You may also want to set up a custom column with a "yes/no" condition for email tracking. I personally only really decide to start following something after I've read what already exists so it is very nice to be able to just check Calibre if I am receiving email notifications of updates for not. So yeah, I honestly, I quite like it in comparison to my old PRS-950. I was worried about the size and shape of the screen but it isn't as bad as I thought it would be. It's pretty slick for page turns and so far I haven't had many problems with fics that don't use wonky formatting. And speaking of formatting. I've notices that a lot of formatting from Xenforo sources seems to be disappearing. Not so much things like italics and bold but I've noticed that when something is supposed to be right justified it isn't properly carried over. Any way to fix that? Last edited by Ryune; 01-17-2018 at 09:29 PM. |
#2580 | ||
Plugin Developer
Tags |
fanfiction |
[GUI Plugin] KindleUnpack - The Plugin | DiapDealer | Plugins | 527 | 08-15-2025 01:36 PM |
[GUI Plugin] Open With | kiwidude | Plugins | 404 | 02-21-2025 05:42 AM |
[GUI Plugin] Marvin XD | Philantrop | Plugins | 126 | 01-29-2017 12:48 PM |
[GUI Plugin] KiNotes | -axel- | Plugins | 0 | 07-14-2013 06:39 PM |
[GUI Plugin] Plugin Updater **Deprecated** | kiwidude | Plugins | 159 | 06-19-2011 12:27 PM |
