Pain in the arse
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 758
Device: Kobo Aura One, Kindle 4
Kobo Installer
I created a simple tool to install patches for Kobo. I get this idea from yoq.
Advantages:
The Installer has also an optional and rudimentary package manager: it prevents installation of older Kobo modifications if a newer version is already installed. Read here for further informations. If you want to use it for your mod, you've simply to:
The package contains also Python 3 interpreter and some of its modules. Here is the entire py3 Standard Library, pyc compiled. Last edited by Lucas Malor; 09-22-2014 at 04:03 AM. |
Pain in the arse
I've modified the Installer, so it will be more simple to use. Furthermore you can install more mods at one time, and only one reboot will be performed.
Pain in the arse
I updated my Kobo Installer. Now it's quite useful and simple to use.
You need no regular expressions, and you can add text after and before some string inside a file. Multiline text can be added as well. This way you can easily and safely patch /etc/init.d/rcS or any other file. I created a simple installer for the Night Mode mod. I created it for testing, but it works perfectly: Night Mode stay installed even after a firmware upgrade, and the installation works on every firmware. I plan to create package for the Kobo Installer also for the Start Menu, KoboLauncher and Koreader. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 13,863
You might like to clarify which version of Kobo f/w this applies to. As a bonus, make the patcher understand and detect different versions to ensure the correct one IS installed.
Additionally, I can see some major benefits to NOT automatically re installing a patch after a f/w upgrade in case of compatibility issues. |
#5 | ||
Pain in the arse
![]() Quote:
Of course this works only if you've installed also the newer version this way. Last edited by Lucas Malor; 08-14-2014 at 02:36 PM. |
Noo... I meant different F/W levels NOT mod levels. I'm thinkiong for instance of the different levels of the nightmode library that are required for different Kobo f/w levels.
Pain in the arse
Yes, if some dev needs it I can add the possibility to specify the target firmware versions. I want to add also simple uninstall mechanism, in such a way that devs have only to write a text file with a list of files to be deleted and a script that reverts the patches. Users will simply have to write in a file the name of the packages they want to be uninstalled the next reboot.
In the immediate future, I'll change the patching behaviour as you suggested: patches will be applied only once. You'll be able to reapply them all, changing a setting to "1". That setting will be reverted to "0" after that. Last edited by Lucas Malor; 08-14-2014 at 06:16 PM. |
Device: Kobo Clara HD
can you make just the python? the new kobolauncher is actually on pbchess
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 50,800
Considering that @Lucas Malor hasn't been heard from in 7 years, I suspect your answer is going to be no.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 82,527
And I suspect that the project is dead.
| Why Use Windows Installer? | abundantmind | Devices | 6 | 12-28-2013 05:53 AM |
| Windows installer changes in 0.8.3 | Manichean | Calibre | 25 | 06-01-2011 10:46 AM |
| Changes to Installer??? | kgn | Calibre | 29 | 01-23-2011 10:40 AM |
| Installer for Reader | shmish | Sony Reader | 6 | 09-01-2010 01:47 PM |
| Installer suggestion | AprilHare | Calibre | 3 | 12-23-2008 11:35 AM |
