Old 04-29-2013, 05:09 AM   #1
simonsezdothis
simonsezdothis began at the beginning.
Device: Kindle Papewhite
Thumbs up Index by date
Hi.
Have been hunting here for an answer to this question but haven't been able to find what I am wanting to know.
I have just upgraded my Kindle Keyboard to a Kindle Paperwhite.
With my Kindle Keyboard, if I transferred files from Calibre they would appear in my device in the same order. I keep them indexed by Author then Publishing Date.
With my Paperwhite they will appear indexed by Author and are then are seemingly randomly assigned. (Does not correspond with 'date' order either)
How do I remedy this?
cheers
Simon
Calibre is awesome
simonsezdothis is offline   Reply With Quote
Old 04-30-2013, 07:14 AM   #2
simonsezdothis
So ... I can see how to use the "Save Template" to change Folder Names etc when sending files to the Paperwhite. {pubdate} doesn't appear to work though. (from Plugin Setup)
This will only change the folder names in my device won't it? Will this also have the effect of re-ordering the titles if the pubdate came first?
Or ...
will I simply have to re-title all my books by prefixing the titles with a number?
Old 04-30-2013, 08:08 AM   #3
You probably just need to change the sorting on your PW, it likely has options ot control how the book list it displays is sorted.
Old 04-30-2013, 06:53 PM   #4
simonsezdothis
Thanks, but the only sort options in the Paper white are Recent, Title and Author.
This is the same as was in my Kindle keyboard.
If sorting by Author (KK) items were also listed by pub date, presumably because that's how they were sorted in Calibre when transferred?
With the PW under Author they are random.
So I guess nothing has changed in Calibre regarding the order the books are transferred? Must just be a PW thing then.
Looks like I'll have to rename everything to get around it.
Thanks anyway.
Program is great
Old 05-01-2013, 12:40 AM   #5
No, nothing has changed in calibre.
Old 05-01-2013, 06:34 AM   #6
DoctorOhh
US Navy, Retired
DoctorOhh's Avatar
Instead of renaming everything try using the metadata plugboards. Note that the metadata plugboards do not work for books converted with the Mobi output - MOBI file type set to both.
Old 05-01-2013, 09:27 PM   #7
simonsezdothis
That works really well, but only if I edit all the publishing dates to the same month.
Is there a way to change this date format also?
Old 05-02-2013, 02:16 AM   #8
DoctorOhh
US Navy, Retired
DoctorOhh's Avatar
Possibly. Preferences - Tweaks and adjust the below tweak.
# Control how dates are displayed
gui_pubdate_display_format = 'yyyy mm'
This may have zero effect on the Pub date being sent to your PW but it is worth a try.
Old 05-04-2013, 12:37 AM   #9
simonsezdothis
Smile
Thanks for that. Works a treat!
Now I have my Paperwhite Book list looking like this, without editing the books themselves.
Tana French - 2007 - In The Woods
Tana French - 2008 - The Likeness
Tana French - 2010 - Faithful Place
Tana French - 2012 - Broken Harbour
etc
This makes a huge difference to me
Calibre is such a great program and the support here is fantastic. (and yes I have donated previousy, and will do so again)
https://www2.mobileread.com/i/smiliesadd1/thumbsup.gif
THANKYOU ALL
Old 05-04-2013, 04:18 AM   #10
DoctorOhh
US Navy, Retired
DoctorOhh's Avatar
You're welcome.
It always amazes me the 1000 different ways folks use calibre.
Publication Date or Copyright Date or ??? hd_cal_dave Library Management 8 05-25-2012 02:50 PM
Index: Making a linked index in epub virtual_ink ePub 21 10-20-2011 12:23 AM
Bulk Changing Published Date To Date hmf Calibre 4 10-19-2010 11:19 PM
Up-to-date candy teacher (date being 1921) kacir Deals and Resources (No Self-Promotion or Affiliate Links) 0 06-16-2010 05:18 PM
new official shipping date / US invitation date R2D2 iRex 18 07-06-2006 03:32 PM
