Go Back   MobileRead Forums > E-Book Readers > Amazon Kindle > Amazon Fire
Old 01-15-2012, 10:49 PM   #1
sugrue
sugrue began at the beginning.
Device: Kindle Fire
Corrupted book format
I thought I saw a post about this here, but am unable to find it by searching. I have downloaded several books from Amazon that appear to be corrupted. When I click on them, the cover comes up, but as I try to move to other pages, they are all blank and the page number does not change. If I drag to 100%, it bounces back to 0%.
This weekend, I downloaded a book from my library and the same thing has happened.
However, I can read them all on my PC using the Cloud Reader with no problems.
Any suggestions?
sugrue is offline   Reply With Quote
Old 01-15-2012, 10:58 PM   #2
Since they work with the Cloud Reader, then I would say they are not corrupted. It could be a problem with the Kindle app on your Kindle Fire. Is it possible to delete the Kindle app and reinstall it? If not, give Amazon CS a call.
Old 01-15-2012, 11:06 PM   #3
Blossom
Treasure Seeker
Blossom's Avatar
Any suggestions?
You could try a factory reset but before I do that I would install Kindle 4 PC and see if you can read it in there first.
If so then it could be your Fire and factory reset is needed.
Old 01-15-2012, 11:55 PM   #4
sugrue
Device: Kindle Fire
Thanks JSWolf and Blossom. I installed Kindle 4 PC and I can read all 3 of the books on it as well as the Cloud Reader, so I guess it is time for a Factory Reset.
Is there anything I need to know before doing the reset? Will I have to re-download all of my books after the reset, for instance?
Old 01-15-2012, 11:59 PM   #5
Blossom
Treasure Seeker
Blossom's Avatar
Back up your stuff. You're amazon books will have to redownloaded yes but you can move your non amazon books to your hard drive.
Old 01-16-2012, 12:14 AM   #6
sugrue
Device: Kindle Fire
Thanks Blossom. I just did the reset and all of the books are readable. Appreciate your help.
Old 01-16-2012, 12:24 AM   #7
Blossom
Treasure Seeker
Blossom's Avatar
If it happens again I would call Amazon and ask for a replacement.
Locked Content of Corrupted File? Book Purchased from Kobo beautifulsoup Kobo Reader 6 12-26-2011 10:35 AM
the need for a new e-book format petrucci General Discussions 21 07-22-2011 02:25 PM
All Book Covers Corrupted on nook? WJMuldowney Calibre 12 09-04-2010 02:37 PM
Classic e book format andrea t Barnes & Noble NOOK 6 02-18-2010 03:19 PM
Audio SD cards corrupted after book loading SciFiReader Sony Reader 1 02-23-2007 04:25 PM
