Old 03-13-2011, 09:54 AM   #361
meme
Sigil developer
meme ought to be getting tired of karma fortunes by now.meme ought to be getting tired of karma fortunes by now.meme ought to be getting tired of karma fortunes by now.meme ought to be getting tired of karma fortunes by now.meme ought to be getting tired of karma fortunes by now.meme ought to be getting tired of karma fortunes by now.meme ought to be getting tired of karma fortunes by now.meme ought to be getting tired of karma fortunes by now.meme ought to be getting tired of karma fortunes by now.meme ought to be getting tired of karma fortunes by now.meme ought to be getting tired of karma fortunes by now.
Device: Kindle PW, K4 NT, K3, Kobo Touch
Originally Posted by drempee View Post
Other bug: the number of the books in collections differs in the device and the plugin. Peter
Could you be more specific about what is different?
meme is offline
Old 03-13-2011, 11:22 AM   #362
hooby
hooby began at the beginning.
Device: kindle
First of all - the new version (1.4.1) of this plugin is great - thanks!
Secondly, I am also seeing discrepancies in the number of books in some collections between the calibre report and what is shown on the Kindle.
For instance, I have 18 Calibre generated newsfeeds. They all have the the author automatically set as "calibre" and also a tag as "News" - which is exactly what I require. 15 of the 18 have News as the first tag - whereas 3 have the News tag last in that field. (I suspect this is the cause of this part of the bug)
The plugin report says I have only 15 items in _News and 17 for the the so-called author "calibre" (there should be 19).
However, the Kindle actually shows only 2 items in the "_News" collection and 4 in the "calibre" collection.
Hope this helps you figure out what is going on....
hooby is offline
Old 03-13-2011, 12:51 PM   #363
meme
Sigil developer
If you use Edit Collections - is it clear which ones are missing?
Or if you look at the bottom of the report where it lists each book and if its adding/ignoring the collection is it clearly adding them?
meme is offline
Old 03-13-2011, 01:34 PM   #364
hooby
Device: kindle
I have just re-run everything (re-booted etc) and this is what I now have :
When looking at "Edit Collections" for "_News" it only shows 10 "included" items. I can see several others that it missed - (e.g Washington Post etc). Calibre itself shows that I have 16 unique feed with the News tag. the Kindle only admits to 1 item in the "_News" collection.
The Kindle also only show 2 items in for the author "calibre".
I post below the relevant parts of the logfile - I am confused when it says
"Not including: Science News Recent Issues (due to include list for column "Tags")"
- I guess I am doing something wrong for this to come up but I cannot see what....
calibre, version 0.7.49
Kindle Collections plugin: 82 collections saved to the Kindle.<P><P>Eject and unplug the Kindle - it will automatically reload the new collections without restarting the Kindle.<P>
=== Kindle Collections 1.4.1 Report
Collections saved to the Kindle:
Collection Managed By Books Change
__Currently Reading Kindle 1 None (matched never delete/modify list)
_A Calibre 16 Replaced (from column "Tags")
_adventure Calibre 4 Replaced (from column "Tags")
_B Calibre 15 Replaced (from column "Tags")
_Biography Calibre 2 Replaced (from column "Tags")
_Business Calibre 12 Replaced (from column "Tags")
_C Calibre 22 Replaced (from column "Tags")
_D Calibre 90 Replaced (from column "Tags")
_F Calibre 10 Replaced (from column "Tags")
_G Calibre 14 Replaced (from column "Tags")
_H Calibre 21 Replaced (from column "Tags")
_History Calibre 5 Replaced (from column "Tags")
_J Calibre 6 Replaced (from column "Tags")
_K Calibre 4 Replaced (from column "Tags")
_L Calibre 10 Replaced (from column "Tags")
_M Calibre 12 Replaced (from column "Tags")
_Mystery & Crime Calibre 24 Replaced (from column "Tags")
_N Calibre 2 Replaced (from column "Tags")
_News Calibre 19 Replaced (from column "Tags")
_O Calibre 5 Replaced (from column "Tags")
....SNIP...
Bill Nye Calibre 2 Replaced (from column "Authors")
calibre Calibre 20 Replaced (from column "Authors")
Canavor, Natalie Calibre 2 Replaced (from column "Authors")
Charles Dickens Calibre 3 Replaced (from column "Authors")
etc.....
***** This is the ONLY item now in the _News collection on the KINDLE - despite what it says above (19)
Chicago Tribune
Kindle path: documents/Chicago Tribune azw-asin_5a86bb80fb2c14af839239e83df22856454a3046-0-azw-type_PDOC-v_0.azw
Kindle code: #5a86bb80fb2c14af839239e83df22856454a3046-0-azw^PDOC
Adding collection: News (from column "Tags")
Adding collection: calibre (from column "Authors")
***** Just 2 examples of those that are NOT on the KINDLELondon Review of Books (free)
Kindle path: documents/News/London Review of Books (free)_2011-3-11.mobi
Kindle code: #635df267-6666-4bc8-a175-1ba6b9ed84ef^None
=== Settings:
Authors
Action: Create
Prefix: ""
Suffix: ""
Minimum: 2
Ignore:
Include:
Rename from:
Rename to:
Action: Create
Prefix: "_"
Suffix: ""
Minimum: 2
Ignore:
Include: News,History,Science Fiction,Biography,Adventure,Mystery & Crime,Business,^\+.*
Rename from: ^\+(.*)$
Rename to: \1
Never delete/modify these Kindle collections: cindy,games,kindle stuff,technical,read,__Currently Reading
Preserve existing Kindle-only collections: False
Ignore prefix/suffix when comparing Calibre names: True
Ignore case when pattern matching: True
Fast reboot using hacks: True
Fast reboot trigger file: I:\linkss\reboot
Kindle collections file: I:\system\collections.json
Plugin customization file: C:\Documents and Settings\Andy\Application Data\calibre\plugins\Kindle Collections.json
Kindle path: documents/News/Science News Recent Issues_2011-3-13.mobi
Kindle code: #47c2f43e-237b-4f8f-8f94-5793ffb92eea^None
=== Settings:
Authors
Action: Create
Prefix: ""
Suffix: ""
Minimum: 2
Ignore:
Include:
Rename from:
Rename to:
Action: Create
Prefix: "_"
Suffix: ""
Minimum: 2
Ignore:
Rename to: \1
hooby is offline
Old 03-13-2011, 01:44 PM   #365
@hooby:
My guess would be the cdetype != PDOC or EBOK is what's messing up things for calibre generated news... AFAIK, calibre *should* correctly set this to PDOC, but I may be wrong. I'll take a look at it.
EDIT: It does, but only when it finds the pdoc tag specified in the mobi output config in the tags of a book when sending it to the Kindle. (On my system, it was set to [PDOC], so my news weren't flagged PDOC either).
Long story short: Set the personnal doc tag to 'News' instead of '[PDOC]' in Pref > Output Options > Mobi output. Every news sent from this point forward should be correctly tagged as cdetype PDOC, and that *should* fix your issue. [Of course, you'll have to resend your back issues to update the metadata in these].
NiLuJe is offline
Old 03-13-2011, 02:20 PM   #366
hooby
Device: kindle
Thanks - I have done what you suggested - I checked meme's logfile and sure enough all the newsfeeds were showing in Kindlecode "^None" except the Chicago Tribune which was set to "^PDOC" - so maybe this will cure this particular issue. I will check once the feeds have been updated tomorrow...
I wonder if these feeds will also now correctly show in the "Author" field for calibre...
hooby is offline
Old 03-13-2011, 02:24 PM   #367
@hooby: You can force a re-fetch of a few feeds to test this .
Not sure what you're referring to with the 'Author' field bit... Fetched news show up fine with 'calibre' as Author for me :?
NiLuJe is offline
Old 03-13-2011, 03:05 PM   #368
drempee
drempee began at the beginning.
Device: Kindle 3
For example there is 36 books in a Kindle collection, and the plugin report says "collection name (68)". There are many collections with false number.
drempee is offline
Old 03-13-2011, 03:15 PM   #369
meme
Sigil developer
I'll look into this and see if I can duplicate it. In the report details at the bottom is there any book that you expect to be in a collection that is not in a collection? Are there any notes like ignoring/skipping? Although the count of what's on the Kindle and what is shown in the report should match so it looks like I need to recheck the code.
Are you restarting the Kindle?
Thanks for reporting it - and welcome to Mobileread !
meme is offline
Old 03-13-2011, 03:18 PM   #370
@drempee: Is there a common trend for the 'missing' books? (ie. News, Topaz, AZW, Mobi, PRC, PDF, Kindlet, weird metadata, etc.).
@meme: Just noticed a tiny mistake that broke Kindlet parsing, here's a patch ^^.
NiLuJe is offline
Old 03-13-2011, 04:04 PM   #371
meme
Sigil developer
Thanks - a bit too much cleanup Will be in next release.
meme is offline
Old 03-13-2011, 05:42 PM   #372
drca001
Experimenter
drca001 began at the beginning.
Not able to create collection
I just installed the most recent version of the Kindle Collections plugin. When I customize the collections plugin and run the "preview" option, I get the following message:
calibre, version 0.7.48
Welcome to the Kindle Collections plugin.<P>
Run "Customize plugin" to configure which collections to create.<P>
Run "Preview without saving collections" to see a test report.<P>
Run "Create collections on the Kindle" to save collections.<P>
I am not able to create any collections even using the examples shown in the original post.
I am running Windows 7 Professional, 64bit
Suggestions please?
drca001 is offline
Old 03-13-2011, 05:49 PM   #373
hooby
Device: kindle
message deleted
hooby is offline
Old 03-13-2011, 05:51 PM   #374
hooby
Device: kindle
Yes, agreed - in Calibre itself the author is set to "calibre". But my Kindle Collections plugin is set to create a collection for 2 or more Authors - and it seems to find 20 "calibre" Authors according to the logfile I posted earlier (post #364) -
However, when the collection is sent to the Kindle and re-booted only 2 items appear in the "calibre" collection - this is what I am referring to..... is it somehow my fault or a bug ?
hooby is offline
Old 03-13-2011, 06:52 PM   #375
swampsnake
swampsnake began at the beginning.
Device: Kindle 3
Suggestions please?
Getting the same thing with Windows 7 Ultimate x64
Does not remember the settings I enter in the customize plugin page and will keep going the the welcome page whenever I try to run preview or create
swampsnake is offline
[GUI Plugin] Kindle Collections (Update) NiLuJe Plugins 477 09-22-2025 02:50 PM
Kindle Collections plugin JosephWebber Plugins 1 08-21-2017 12:44 PM
[GUI Plugin] WebOS Kindle-Import CranstD Plugins 0 01-24-2012 04:36 PM
Finding and using Kindle Collections Plugin djchapple Plugins 2 08-03-2011 11:06 AM
