![]() ![]() ![]() Posts: 190
Device: iPhone 11 (Kindle app & iBooks)
libprs500 linux install error
Hey, can anyone help me with this install error? I'm trying to install on FreeBSD (linux-like). Something is wrong about udev? I don't have any directory /etc/udev on my system. Am I missing something that needs to be installed or running?
The error is: Code:
root@oom9:/root>easy_install-2.5 -U TTFQuery libprs500 && libprs500_postinstall
Searching for TTFQuery
Reading http://cheeseshop.python.org/pypi/TTFQuery/
Reading http://members.rogers.com/mcfletch/
Reading https://sourceforge.net/project/showfiles.php?group_id=84080
Reading http://cheeseshop.python.org/pypi/TTFQuery/1.0.0
Best match: TTFQuery 1.0.0
Processing TTFQuery-1.0.0-py2.5.egg
TTFQuery 1.0.0 is already the active version in easy-install.pth
Using /usr/local/lib/python2.5/site-packages/TTFQuery-1.0.0-py2.5.egg
Processing dependencies for TTFQuery
Searching for libprs500
Reading http://cheeseshop.python.org/pypi/libprs500/
Reading http://libprs500.kovidgoyal.net
Reading http://cheeseshop.python.org/pypi/libprs500/0.3.106
Best match: libprs500 0.3.106
Downloading http://pypi.python.org/packages/2.5/l/libprs500/libprs500-0.3.106-py2.5.egg#md5=983b0bb1cae1c98dcdf1401239dba931
Processing libprs500-0.3.106-py2.5.egg
Moving libprs500-0.3.106-py2.5.egg to /usr/local/lib/python2.5/site-packages
Removing libprs500 0.3.101 from easy-install.pth file
Adding libprs500 0.3.106 to easy-install.pth file
Installing libprs500-beta script to /usr/local/bin
Installing lrf-meta script to /usr/local/bin
Installing markdown script to /usr/local/bin
Installing pdf-meta script to /usr/local/bin
Installing rtf-meta script to /usr/local/bin
Installing web2lrf script to /usr/local/bin
Installing any2lrf script to /usr/local/bin
Installing pdf2lrf script to /usr/local/bin
Installing web2disk script to /usr/local/bin
Installing html2lrf script to /usr/local/bin
Installing libprs500_postinstall script to /usr/local/bin
Installing prs500 script to /usr/local/bin
Installing txt2lrf script to /usr/local/bin
Installing lit2lrf script to /usr/local/bin
Installing rtf2lrf script to /usr/local/bin
Installing libprs500 script to /usr/local/bin
Installed /usr/local/lib/python2.5/site-packages/libprs500-0.3.106-py2.5.egg
Processing dependencies for libprs500
Trying to setup udev rules...
File "/usr/local/bin//libprs500_postinstall", line 8, in <module>
load_entry_point('libprs500==0.3.106', 'console_scripts', 'libprs500_postinstall')()
File "build/bdist.linux-i686/egg/libprs500/linux.py", line 192, in post_install
File "build/bdist.linux-i686/egg/libprs500/linux.py", line 172, in setup_udev_rules
IOError: [Errno 2] No such file or directory: '/etc/udev/rules.d/95-libprs500.rules'
root@oom9:/usr/local/bin>libprs500
File ".//libprs500", line 8, in <module>
load_entry_point('libprs500==0.3.106', 'gui_scripts', 'libprs500')()
File "build/bdist.freebsd-5.5-STABLE-i386/egg/pkg_resources.py", line 236, in load_entry_point
File "build/bdist.freebsd-5.5-STABLE-i386/egg/pkg_resources.py", line 2097, in load_entry_point
File "build/bdist.freebsd-5.5-STABLE-i386/egg/pkg_resources.py", line 1830, in load
File "build/bdist.linux-i686/egg/libprs500/gui/main.py", line 21, in <module>
ImportError: No module named QtGui
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 46,013
You can ignore the installation error. The error you get while running it is because you haven't installed PyQt
| Advert | |
Okay, I'm working on that now. I'll let you know how it goes. Thanks.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 532
Device: Kobo Aura One, iPad, iPhone
I keep meaning to put it into a freebsd port, just haven't had time yet (I maintain a few others so it shouldn't be too hard!)
Now I get this error:
root@oom9:/root>libprs500
File "/usr/local/bin//libprs500", line 8, in <module>
File "build/bdist.linux-i686/egg/libprs500/gui/main.py", line 23, in <module>
root@oom9:/root>
| Advert | |
That error message also indicates an incomplete install of PyQt.
simond, would you happen to have a list of the freebsd ports I need installed to get this to run? Maybe I'm installing the wrong ones. So many have "py" and "qt" in the names. I've tried installing the more basic looking ones, but it's clearly not working. I've got:
py25-clientform-0.2.7 Client-side HTTP Form for Python py25-game-1.7.1_2 A module designed to write games in Python py25-mechanize-0.1.6.b Stateful programmatic web browsing in Python py25-numeric-24.2 The Numeric Extension to Python py25-qt4-core-4.2_1 Python bindings for the Qt4 toolkit, QtCore module py25-qt4-gui-4.2_1 Python bindings for the Qt4 toolkit, QtGui module py25-qt4-qscintilla2-20070410_1 Python bindings for QScintilla2 (PyQt4), QSci module py25-setuptools-0.6c5 Download, build, install, upgrade, and uninstall Python pac py25-sip-4.6,1 Python to C and C++ bindings generator python-2.5,2 The "meta-port" for the default version of Python interpret python24-2.4.4_1 An interpreted object-oriented programming language python25-2.5.1 An interpreted object-oriented programming language qca-tls-1.0_2 SSL/TLS plugin for Qt qmake-3.3.8_1 The build utility of the Qt project qscintilla2-20070410_1 Qt4 port of the Scintilla C++ editor class qt-copy-3.3.8_5 Multiplatform C++ application framework (+ KDE patches) qt4-corelib-4.3.1 Qt core library qt4-gui-4.3.1 Qt graphical user interface library qt4-iconengines-4.3.1 Qt SVG icon engine plugin qt4-imageformats-4.3.1 Qt imageformat plugins for GIF, JPEG, MNG and SVG qt4-moc-4.3.1 Qt meta object compiler qt4-qmake-4.3.1 The build utility of the Qt project qt4-rcc-4.3.1 Qt resource compiler qt4-svg-4.3.1 Qt SVG library qt4-uic-4.3.1 Qt user interface compiler qt4-xml-4.3.1 Qt XML library |
That's part of the problem, I've not had a chance to even get it working yet, I have the drawback of a 3 month old son who takes most of my non work time
| Linux Install Help | rmatakajr | Calibre | 3 | 08-25-2010 07:22 PM |
| linux install error | alexxx | Calibre | 3 | 07-20-2010 11:31 AM |
| cannot install in on Linux | ichthyosaur | Calibre | 1 | 12-31-2009 06:20 PM |
| Linux install | roger64 | Calibre | 2 | 04-23-2009 04:30 AM |
| Ubuntu 7.10 90% of libprs500 install... | knewbie | Calibre | 3 | 12-24-2007 05:38 PM |
