#601 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 19
Scriptoria: Literata 3 with Literata Book Metrics
Here's Scriptoria, Literata 3 with Literata Book metrics
#602 |
![]() Posts: 2
Device: kobo libra color
Hi, i was searching for a font for Korean alphabet. Which one works for that?
#603 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 54,404
The few times I've played with Hangul, I used Noto Serif Korean.
#604 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 724
Device: Kindle Paperwhite 6
Please could someone do a standard Bookerly font with added weight? Thanks.
#605 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 84,893
#606 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 733
Device: Kobo Libra
I did one ages ago, I don't have it anymore but must be somewhere around here.
There is merit to doing it, usually performs better than on-the-fly adding weights. |
#607 |
If there is a version of Bookerly with weight added to it on MR, then it has to go as it's not allowed to be posted without Amazon's permission.
#608 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 334
Chapparal Pro was removed, but it doesn't say why.
I've downloaded and modified a copy of it, and it is working at 99.99%. I've just found one nit that I don't know how to fix. In a couple of books that have nested quotations, I have seen authors insert a small space between the single quote and the double quote. When I open it in the Calibre editor, it is identified as "THIN SPACE". Chapparel Pro doesn't appear to have that character, and so it throws up a box with an X in it between the quote marks. If I switch to Rakutan Serif, it is displayed properly, so it isn't a Kobo issue. Is there a relatively easy way to fix this? I have FontForge, but very little knowledge of how it works. |
#609 | |
#610 | |
The Supplemental Font idea should have worked, but it doesn't. There must be an entry under U+2009 rather than a null. I'll try deleting that character. Also, Rakutan Serif seems to be the only font that properly displays that character. (For some reason, my Supplemental Font was set to AR UDJingxihei, even though I have never viewed an Asian font.) If that doesn't work, I suppose I could just delete the THIN SPACE from the book and deal with the visual of '", which I wouldn't mind. Last edited by fogice; 08-07-2025 at 02:55 PM. |
#611 |
Are you certain there is a glyph at the point? It seems to show the Xed out block for unused fonts.
#612 |
I'm seeing the same as you. So my guess was wrong. I don't know why setting Rakutan Serif as the supplementary font doesn't fix this, or have any ideas other than deleting the offending character from the book.
#613 |
ChareInk7SP has been posted based on Charis SIL 7. Enjoy.
https://www.mobileread.com/forums/sh...d.php?t=184056 |
#614 | |
#615 | |
| Glo Summary | sunny1z | Kobo Reader | 1 | 01-18-2013 08:46 AM |
| Troubleshooting Reading Notes on K3 in Summary | sirmaru | Amazon Kindle | 0 | 09-26-2010 07:55 PM |
| book summary in reader | coolnamehere | Calibre | 2 | 06-06-2010 04:01 PM |
| Book Summary | persiphone | Calibre | 5 | 03-05-2009 01:51 PM |
| Book summary | macphersondh | Sony Reader Dev Corner | 13 | 12-21-2008 08:25 PM |
