Old 07-15-2024, 10:48 AM   #1
SvenLotus
SvenLotus began at the beginning.
How to merge multiple epub files into one?
I have downloaded a 14 part story as individual html files. I then imported each individual html file into calibre. Now I would somehow like to merge all 14 individual epub files into one epub file where each of the original individual files becomes a single chapter in the larger combined epub file.
I have searched around and I do not see a way to do this.
Is this possible or not?
SvenLotus is offline   Reply With Quote
Old 07-15-2024, 11:01 AM   #2
I hope you did not fully rely on the MR search tool as it throws a lot of extra stuff.
EPUB Merge the Plugin (fast for doing multi-section books, doing add-on's)
Old 07-15-2024, 11:18 AM   #3
SvenLotus
I did download the Epubmerge plugin source3 but there are no driections for how to use it. I did use the setup.py file included in the source to install it but when I try to run it from the command line I get the following error:
$ epubmerge
File "/usr/local/bin/epubmerge", line 11, in <module>
load_entry_point('EpubMerge==3.0.0', 'console_scripts', 'epubmerge')()
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 490, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2854, in load_entry_point
return ep.load()
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2445, in load
return self.resolve()
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2451, in resolve
module = __import__(self.module_name, fromlist=['__name__'], level=0)
ModuleNotFoundError: No module named 'epubmerge'
Now since this is called a "plugin" I would have thought it should somehow be imported to calibre as a plugin like a plugin in GIMP or a webbrowser but again I was not able to find any documentation on how to import a plugin to calibre.
Old 07-15-2024, 11:36 AM   #4
PeterT
Preferences, Plugins, install plugin
See https://manual.calibre-ebook.com/gui.html#preferences
Sent from my Pixel 7a using Tapatalk
Old 07-15-2024, 11:54 AM   #5
SvenLotus
OK, I managed to install the EpubMerge plugin but I cannot figure out how to activate it from the calibre desktop UI
If I go to preferences -> Plugins it says it is under "User interface action" but how do I actually make use of the plugin?
Old 07-15-2024, 02:02 PM   #6
Proper installation should have created an icon on the toolbar
(merge is on the left here. Split on the right is a 'companion' PI )
Preferences Toolbars is where you can change what / where these appear
BTW The default is with the DEVICE DISCONNECTED
Old 07-15-2024, 02:05 PM   #7
dunhill
dunhill's Avatar
You select the files in the main Calibre view and tap the arrow to the right of the plugin icon and select combine the files
Old 07-15-2024, 06:06 PM   #8
SvenLotus
Thanks to everyone who responded
I got it working
Calibre-merge 2 language ePub files smashingpuffins Editor 4 01-06-2015 07:14 AM
is it possible to merge multiple text files looking like a magazine on kindle? 42mm Library Management 1 04-01-2013 09:09 AM
How to merge multiple azw files into one Fabius Workshop 2 10-04-2012 03:26 PM
Is there a way to merge all the files Calibre outputs into one epub? Library woes. Patass Library Management 5 02-22-2011 08:54 PM
Merge multiple XHTML files at once gmw Sigil 1 12-28-2010 03:35 AM
