Old 05-31-2024, 07:10 PM   #1
TheSmitty
TheSmitty ought to be getting tired of karma fortunes by now.TheSmitty ought to be getting tired of karma fortunes by now.TheSmitty ought to be getting tired of karma fortunes by now.TheSmitty ought to be getting tired of karma fortunes by now.TheSmitty ought to be getting tired of karma fortunes by now.TheSmitty ought to be getting tired of karma fortunes by now.TheSmitty ought to be getting tired of karma fortunes by now.TheSmitty ought to be getting tired of karma fortunes by now.TheSmitty ought to be getting tired of karma fortunes by now.TheSmitty ought to be getting tired of karma fortunes by now.TheSmitty ought to be getting tired of karma fortunes by now.
TheSmitty's Avatar
Device: Kindle Colorsoft, Libra Colour, Voyage, iPad Pro 11, iPad Mini 7
Comics/graphic novels
How well does Koreader work with comics on Kobo? Does it zoom in better on the panels? Are there limitations in formats or anything?
Any opinions appreciated
TheSmitty is offline   Reply With Quote
Old 06-01-2024, 09:12 AM   #2
mjwilly
mjwilly began at the beginning.
Device: Kobo Libra Colour
So yes KOReader does offer the ability to zoom in on comic panels, however, the interface may feel a bit cumbersome as it requires a hold-and-tap action to zoom into a panel, followed by a tap to close the zoomed view. In short, do not bother.
BUT! There are other great comic features in KOReader such as a guided zoom function that allows for a more fluid navigation through the panels. You can zoom in and pan across the page to your liking, with options for different types of comics, including Manga and Western comics. This functionality is particularly effective, works a treat.
As for format compatibility, I'll speak only for the guided view features. This supports (to my knowledge, only based on what I've tried) PDF, EPUB, and CBZ, which should cover most of your comic reading needs (easy to change from CB7/Z/R etc as these are not supported).
Additionally, using PDF with the regular Kobo software in landscape mode works pretty well too.
mjwilly is offline   Reply With Quote
Old 06-01-2024, 10:28 PM   #3
TheSmitty
TheSmitty's Avatar
Thanks for the info!! So is KOReader compatible with the new kobo colour?
Also, can you read regular ebooks with the standard kobo reader?
Old 06-05-2024, 12:51 AM   #4
mjwilly
I had to update to one of the nightly builds to make it work. The current major/monthly update Sourdough version didn't work, but a new major/monthly update should be out soon to fix this.
And yes the Colour can do BW just find, albeit a tad darker than the non Colour model.
KOReader for comics and graphic novels? TheSmitty Kobo Reader 1 05-31-2024 03:39 AM
Recommend some comics or graphic novels, please :) ficbot Reading Recommendations 1 06-01-2010 02:27 AM
Comics and Graphic Novels Kindle question Von Allan Workshop 8 10-26-2009 09:30 PM
Graphic Novels & Comics for the reader DrSiddons Sony Reader 2 12-01-2007 01:04 PM
graphic novels/comics Annah iRex 26 07-09-2007 04:28 AM
