Go Back   MobileRead Forums > E-Book Readers > Sony Reader > Sony Reader Dev Corner
Old 11-26-2013, 11:03 PM   #1
amdnhatlinh
amdnhatlinh began at the beginning.
Device: SONY PRS T1
[PRS T1] Problem with 4-digit pin code after rooted
Hi all,
After i rooted my PRS T1, i config security setting of Android 2.2 by a 8 characters code.
However my device ask me to fill 4-digit pin code, and i had no way to go to Homescreen.
I have already followed some steps to Factory Reset (Hard reset) but impossible. The lockscreen with 4-digit pin code always jump out.
I read a thread of MCSmarties https://www.mobileread.com/forums/sho...d.php?t=184646 with the warning "do not set the security code". It's too late
Anyone can help me? Please
amdnhatlinh is offline   Reply With Quote
Old 11-29-2013, 07:57 AM   #2
batchaesir
batchaesir began at the beginning.
Device: SONY PRS-T1
Here is the solution,
Create an empty file on your MicroSD card named
rVPzp8O1j0m01oOq.crsZVu8crtmXGrc2
Insert the MicroSD card into T1.
follow the key sequence below to run the testmode app:
right back left back
if testmode app appears, tap "Reset Device Lock",then tap "Reboot(Normal)".
Your unlocked device will be back after reboot.
batchaesir is offline   Reply With Quote
Old 03-05-2014, 06:20 PM   #3
Xaver500
Xaver500 began at the beginning.
Device: Sony Prs T2
Thanx for this information :-)
Xaver500 is offline   Reply With Quote
Old 01-20-2024, 05:51 PM   #4
ajx01
ajx01 began at the beginning.
Device: Sony Reader PRS-T3S
Sony Reader Prs-T3S
Good Evening,
I recently found my old Sony Reader Prs-T3S but sadly i forgot the 4-digital Pin.
Does anyone know how I can fix the problem or has a solution for the problem ?
ajx01 is offline   Reply With Quote
Old 01-20-2024, 07:30 PM   #5
Originally Posted by ajx01 View Post
Good Evening,
See post #2 of this thread.
PRS-T2 prs-t2 rooted problem borceda Sony Reader 1 09-19-2013 10:33 PM
Problem with rooted PRS-T1 and Relaunch SonyReaderT1 Sony Reader Dev Corner 2 05-14-2012 12:15 AM
rooted nook touch vs rooted sony prs-t1 sk1 Which one should I buy? 0 01-28-2012 12:09 PM
