Go Back   MobileRead Forums > E-Book Readers > Windows Devices
Old 09-27-2023, 02:15 AM   #1
phoebe_figalilly
phoebe_figalilly began at the beginning.
Device: Kindle Fire HDX
Failed to open
I can't open any books in Windows 10. I get the message
probably some software such as an antivirus or file sync program running on your computer has locked the files
But there are no directions on how to fix the problem.
What do I do?
phoebe_figalilly is offline   Reply With Quote
Old 09-27-2023, 05:02 AM   #2
Try turning off your AV and see how you get on.
Old 01-12-2024, 10:05 AM   #3
Dsharma
Dsharma ought to be getting tired of karma fortunes by now.Dsharma ought to be getting tired of karma fortunes by now.Dsharma ought to be getting tired of karma fortunes by now.Dsharma ought to be getting tired of karma fortunes by now.Dsharma ought to be getting tired of karma fortunes by now.Dsharma ought to be getting tired of karma fortunes by now.Dsharma ought to be getting tired of karma fortunes by now.Dsharma ought to be getting tired of karma fortunes by now.Dsharma ought to be getting tired of karma fortunes by now.Dsharma ought to be getting tired of karma fortunes by now.Dsharma ought to be getting tired of karma fortunes by now.
Dsharma's Avatar
I would suggest checking the settings of your antivirus software to see if it is scanning or blocking access to your book files. Also, if you have any file synchronization services (like Dropbox, Google Drive, or OneDrive), make sure they are not actively syncing the folder where your books are stored, as this can sometimes cause access issues.
Another solution you might want to consider is using a dedicated eBook management tool. For Windows 10, a user-friendly option is https://bibliovore.en.softonic.com/. This software is designed for managing and reading eBooks on Windows devices, and it can offer a smoother experience with your Kindle Fire HDX books.
Dsharma is offline   Reply With Quote
Old 01-12-2024, 08:25 PM   #4
Sirtel
Sirtel's Avatar
Device: Kobo Sage & Libra 2
There's Calibre. 'Nuff said. Nothing else even comes close to it.
Old 01-15-2024, 06:27 AM   #5
Dsharma
Dsharma's Avatar
Hi Sirtel,
I totally agree that Calibre is a great choice for eBook management. However, I suggested Bibliovore as an alternative, particularly for users who might find Calibre a bit overwhelming due to its extensive features. Bibliovore has a more simplified and intuitive interface, which can be appealing for those who are looking for a straightforward eBook reader and manager for their Windows 10 devices.
It's always great to have multiple options, and the choice between Calibre and Bibliovore often comes down to personal preference and specific needs.
Old 01-17-2024, 03:48 PM   #6
Quoth
Still reading
Quoth's Avatar
Another solution you might want to consider is using a dedicated eBook management tool. For Windows 10, a user-friendly option is https://bibliovore.en.softonic.com/. .
Broken web site. The basics of Calibre are intuitive and there is a good manual.
Mac, Windows and Linux. Currently 7.x
Even the ancient 1.48 on XP is still fine, though you'd have to use send to folder for newer devices.
Old 01-18-2024, 04:46 PM   #7
The OP has not been back since posting in this thread. I suggest we stop trying to find a fix for someone who either doesn't care or has solved the problem. Either was the OP has not been back. This thread is dead.
Failed to open Arason Calibre 1 03-05-2023 10:09 PM
failed: Failed to open the book at.... Naleur Conversion 3 11-09-2022 06:00 AM
calibre, version 4.2.0 ERROR: Could not open book: Failed to load book manifest Ankular Calibre 3 11-09-2019 09:29 PM
Failed to Open File NegoGal iRiver Story 5 01-31-2014 08:15 PM
Help duokan Open failed Climber Kindle Developer's Corner 3 01-20-2011 07:33 PM
