#436 |
![]() Posts: 6
Device: Kindle 2
Just used Calibre to convert an HTML book to epub to view in Stanza on my iPhone. All worked great. One issue: While the EPUB is properly broken up into chapters, I don't see any chapters in the list of chapters on the iPhone.
I'll try to explain better: When I'm in a section of the book in Stanza it says that it's an 'Untitled Chapter' consisting of (for example) 17 pages. When I get to the end of the section it loads the next chapter properly. The problem is when I click the little book icon to see my bookmarks and chapters, there are no chapters in the chapters section. Is this a known issue or am I just doing something wrong? Thanks, Bill |
#437 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 46,616
If you open the book in calibre (click the view button) and then click the table of contents button in the viewer, does it show a list of chapters?
#438 |
![]() Posts: 6
Device: Kindle 2
No.. that button is greyed out. Weird that Stanza seems to see the chapter breaks though, huh?
#439 |
Ah well you need to have a Table of Contents. You will have to play with the automatic Table of Contents creation options to get it to work
#440 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 610
Device: Sony Reader PRS-T3, Kobo Libra H2O
What exactly does option --profile do? I kind of hoped it would optimize (resize, convert to grayscale) images to device's dimensions, but that's apparently not the case.
#441 |
I am of the opinion that optimizing images for a device is not worth it, since it renders the ebook sub-optimal for future devices, for only a small gain. Of course for image centric publications like comics, calibre does optimize the images.
profile is used for making device specific changes to the EPUB without which the EPUB would not work on the device. The primary reason for this is that Adobe went and designed their own HTML rendering engine, which has a lot of quirks, so devices using ADE have quirky support for EPUB. |
#442 | ||
#443 |
What reader is this? The 505? And its refusing to display images larger than the screen size? In my experience it rescales those images just fine.
#444 |
I experience two behaviors with 505 and large images:
1) If the images are sufficiently large (e.g. 3100*5000), they are not displayed at all. That is, there is no image, but the reader takes a long time to render this "no image". 2) If the images are smaller but still large enough (e.g. 1100*1500), they are clipped, not resized. |
#445 |
OK if you can figure out threshold above which images are clipped, I'll add that to the SONY profile and have calibre resize images above that threshold.
#446 |
Will do.
#447 |
PRS-505, firmware build 18040.
test.htm: Code:
<?xml version="1.0" encoding="windows-1250"?> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta http-equiv="content-type" content="text/html; charset=windows-1250" /> <title>Test</title> </head> <body> <div class="image"><img src="obr1.jpg" alt="" /></div><hr /> <div class="image"><img src="obr2.jpg" alt="" /></div><hr /> <div class="image"><img src="obr3.jpg" alt="" /></div><hr /> <div class="image"><img src="obr4.jpg" alt="" /></div><hr /> <div class="image"><img src="obr5.jpg" alt="" /></div><hr /> </body> </html> command line: Code:
any2epub test.htm As far as rendering is concerned: - Images 1, 2 and 3 are displayed as empty space approximately 170 pixels high - Image 4 is displayed cropped to a section from (0, 0) (left, top) to approximately (570, 750) (right, bottom) - Image 5 is cropped vertically also to about 750 pixels; horizontally, it fits My conclusion: 1) Very large images are not displayed at all 2) Images larger than screen resolution of the Reader are cropped to fit, not stretched I can, if you like, try to find the exact dimensions when a picture stops being shown, but considering #2, it seems pointless - if it is too large, it will get cropped (and become unusable) anyway. If the --profile=prs505 is used, the images that are larger than about 600x750 should be resized to this resolution while keeping aspect ratio. Smaller pictures should be left alone. If possible, this behavior should be used for all pictures - embedded AND cover. |
#448 | |
GuteBook/Mobi2IMP Creator
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,958
) got shrunk down to accomodate.
#449 | |
#450 | |
reader
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 6,977
Device: Kindle 3, Kobo Glo HD
Does any ePub reader automatically rescale images? This seems to be yet another hole in the ePub specs. |
| [Old Thread] Epub Output: Line Height | greenapple | Conversion | 20 | 01-27-2013 10:27 AM |
| EPUB output justification | toki08 | Calibre | 10 | 01-08-2011 05:14 PM |
| Calibre epub output details and Nook | squidward | Calibre | 6 | 11-24-2010 04:21 PM |
| epub output metadata | troymc | Calibre | 5 | 05-22-2010 01:23 AM |
| Problem with epub output in Cybook Gen3 | fjf | Calibre | 3 | 02-03-2010 03:23 AM |
