Old 12-26-2020, 02:58 PM   #196
ownedbycats
Custom User Title
ownedbycats's Avatar
Originally Posted by capink View Post
However, from looking at your debug, one possible problem is that I did not account for program paths with spaces (missed this because it does not happen on linux). The version I will post later today will correct this by double quoting the program we are calling. If this does not help, I cannot offer much assistance with this.
I actually thought something like that might've happened. If you don't enclose the application path, you get something like "C:\Program is not recognized blah blah blah."
This time I did get an error in Ransack, which seems to indicate that AC tried to send the paths before the argument (the intended command-line is posted in #192 for reference). Not sure if that's another Linux difference.*
2020.12.26 14:56:07:786 Unexpected command line parameter: D:\Documents\My Books\Jenny Oldfield\Starlight (5627)
New debug:
Action Chains: Starting chain: Search with Agent Ransack
Action Chains: Search with Agent Ransack: starting action No. 1: Open With
Open:  C:\Program Files\Mythicsoft\Agent Ransack\AgentRansack.exe (file):  "D:\Documents\My Books\Jenny Oldfield\Steamboat Charlie (5626)" "D:\Documents\My Books\Jenny Oldfield\Starlight (5627)"  (args):  -d mutiple:  True
About to run a command: C:\Program Files\Mythicsoft\Agent Ransack\AgentRansack.exe
Job Spy: self.gui.tags_view.recount() is enhanced for showing icons of user category child values...
Action Chains: chain (Search with Agent Ransack) finished in: 0.28754210472106934
* I once managed to screw up and get a filename with a colon in Windows, which isn't ever supposed to happen. I couldn't do anything with it from within the Windows environment because the path was invalid. Eventually grabbed a Linux boot disk. That was able to rename it.
Old 12-26-2020, 03:51 PM   #197
capink
capink ought to be getting tired of karma fortunes by now.capink ought to be getting tired of karma fortunes by now.capink ought to be getting tired of karma fortunes by now.capink ought to be getting tired of karma fortunes by now.capink ought to be getting tired of karma fortunes by now.capink ought to be getting tired of karma fortunes by now.capink ought to be getting tired of karma fortunes by now.capink ought to be getting tired of karma fortunes by now.capink ought to be getting tired of karma fortunes by now.capink ought to be getting tired of karma fortunes by now.capink ought to be getting tired of karma fortunes by now.
OK, I changed the way multiple selections work (not sure how this affects macos). I replaced the previous test version with another one (in the same post).
If this one does not work, or breaks the functionality for other platforms, I will remove the multiple selections and revert to a simpler one selection only. I need someone to confirm that this is working on macos at least for single selections.
Also, I need the debug output for your first problem with the action condition, that is more critical to deal with.
capink is offline   Reply With Quote
Old 12-26-2020, 04:18 PM   #198
<snip>
Colons in NTFS file names are legitimate. Firstly the one we all know and hate, after a device name e.g. "D:".
They are also used to delimit Alternate Data Stream names. Notepad knows about them - create a file (e.g.my.file), and then run the command: "notepad my.file:note".
See https://en.wikipedia.org/wiki/NTFS#A...eams_.28ADS.29
Old 12-26-2020, 04:25 PM   #199
ownedbycats
Custom User Title
This time, I got the "unexpected command line parameter" for both books.
Ransack's error log:
2020.12.26 16:14:42:871 App version: 8.5.2951.1
2020.12.26 16:14:44:296 Unexpected command line parameter: D:\Documents\My Books\Jenny Oldfield\Steamboat Charlie (5626)
2020.12.26 16:14:45:062 Unexpected command line parameter: D:\Documents\My Books\Jenny Oldfield\Starlight (5627)
2020.12.26 16:14:46:061 Search stopped
Debug log.
Open:  C:\Program Files\Mythicsoft\Agent Ransack\AgentRansack.exe (file):  ['D:\\Documents\\My Books\\Jenny Oldfield\\Steamboat Charlie (5626)', 'D:\\Documents\\My Books\\Jenny Oldfield\\Starlight (5627)']  (args):  -d sep:   ;
Action Chains: chain (Search with Agent Ransack) finished in: 0.22805213928222656
edit: moving conditional stuff to new post
Old 12-26-2020, 06:34 PM   #200
capink
Also, the single field edit conditional is working now. Debug if you need it anyways (sorry for length, wasn't sure what was relevant):
That's strange because I have not changed anything in the conditions code except for more debug statements. Are you sure it wasn't working yersterday?
Ransack's error log
Another version attached to the same post. Hopefully this one does it.
Old 12-26-2020, 06:46 PM   #201
ownedbycats
Custom User Title
The conditional seems to be working now. Here's some debug info if you want to see it anyways.
Here's the chain:
        "active": true,
        "chain_settings": {
          "chain_links": [
              "action_name": "Single Field Edit",
              "action_settings": {
                "col_name": "#percentread",
                "value_type": "prompt"
              "comment": "Set #percentread column",
              "condition_settings": {
                "cmp_type": "=",
                "datatype": "number",
                "template": "program: globals(selection_count)",
                "value": 1.0
              "action_name": "Calibre Actions",
                "disable_busy_cursor": true,
                "selection": [
                    "display": "Store/Restore current bookmark",
                    "path": [
                      "KoboUtilities",
                    "paths_text": "Store/Restore current bookmark"
              "comment": "Restore bookmarks"
                "selection": [
                    "display": "Upload covers for Selected Books",
                    "path": [
                      "KoboUtilities",
                    "paths_text": "Upload covers for Selected Books"
              "comment": "Re-upload cover"
                "col_name": "#onkobo",
                "value": true,
                "value_type": "predefined"
              "comment": "Update #onkobo column"
          "refresh_gui": true
          "cmp_type": "=",
          "datatype": "text",
          "template": "program: connected_device_name('main')",
          "value": "Kobo Aura HD"
        "image": "sync.png",
        "menuText": "Restore Device Bookmarks",
        "subMenu": ""
        "active": true,
        "chain_settings": {},
        "image": "",
        "menuText": "",
        "subMenu": ""
Debug log (I canceled the restore and re-upload):
debug1: run_check: global_vars: {'_chain_name': 'Quick Open Tags Manager', '_chain_iteration': '1', 'location': 'library', 'selection_count': '1'}
    template: program: globals(selection_count)
    value: 1.0
    operator: <built-in function eq>
    template_output: 1
debug2: template_output: 1.0
    output_type: <class 'float'>
debug3: condition_settings: {'cmp_type': '=', 'datatype': 'number', 'template': 'program: globals(selection_count)', 'value': 1.0}
    current_selection_count: 1
    is_true: True
debug1: run_check: global_vars: {'_chain_name': 'Restore Device Bookmarks', '_chain_iteration': '1', 'location': 'library', 'selection_count': '1'}
    template: program: connected_device_name('main')
    value: Kobo Aura HD
    template_output: Kobo Aura HD
debug2: template_output: Kobo Aura HD
    output_type: <class 'str'>
debug3: condition_settings: {'cmp_type': '=', 'datatype': 'text', 'template': "program: connected_device_name('main')", 'value': 'Kobo Aura HD'}
    is_true: True
Action Chains: Starting chain: Restore Device Bookmarks
debug1: run_check: global_vars: {'_chain_name': 'Restore Device Bookmarks', '_chain_iteration': '1', 'location': 'library', 'selection_count': '1', '_action_name': 'Single Field Edit', '_action_comment': 'Set #percentread column', '_action_index': '0'}
    value: 1.0
    template_output: 1
    is_true: True
Action Chains: Restore Device Bookmarks: starting action No. 1: Single Field Edit
debug1: run_check: global_vars: {'_chain_name': 'Restore Device Bookmarks', '_chain_iteration': '1', 'location': 'library', 'selection_count': '1', '_action_name': 'Calibre Actions', '_action_comment': 'Restore bookmarks', '_action_index': '1'}
    value: Kobo Aura HD
    is_true: True
Action Chains: Restore Device Bookmarks: starting action No. 2: Calibre Actions
Actions Chains: Calibre Actions: paths > ['KoboUtilities', 'Store/Restore current bookmark']
Actions Chains: Calibre Actions: Found action: &Store/Restore current bookmark
DEBUG:  200.6 Have a Kobo device connected connected
DEBUG:  200.6 BEGIN Get Device Path
DEBUG:  200.6 Root path of device: K:\
DEBUG:  200.6 END Get Device Path
DEBUG:  200.6 KoboUtilities:get_device - self.device_path="K:\"
DEBUG:  200.6 KoboUtilities:get_device - drive_info: {'main': {'device_store_uuid': '97dc9975-085a-4dc5-a7f4-a614689983f3', 'device_name': 'Kobo Aura HD', 'prefix': 'K:/', 'date_last_connected': '2020-12-26T22:44:05.310516+00:00', 'location_code': 'main', 'last_library_uuid': 'b96decbc-fcca-470f-b7af-8e1338a26310', 'calibre_version': '5.8.1'}}
DEBUG:  200.6 migrate_library_config_if_required - start
DEBUG:  200.6 get_library_config - library_config: {'SchemaVersion': 0.1, 'profiles': {'Kobo Aura HD': {'customColumnOptions': {'currentReadingLocationColumn': '#kobobookmark', 'lastReadColumn': '#lastread', 'percentReadColumn': '#percentread', 'ratingColumn': 'rating'}, 'forDevice': '97dc9975-085a-4dc5-a7f4-a614689983f3', 'profileName': 'Kobo Aura HD', 'storeOptionsStore': {'storeOnConnect': False, 'promptToStore': False, 'storeIfMoreRecent': True, 'doNotStoreIfReopened': False}, 'updateOptionsStore': {'doEarlyFirmwareUpdate': False, 'doFirmwareUpdateCheck': False, 'firmwareUpdateCheckLastTime': 0}}}, 'readingPositionChangesStore': {'selectBooksInLibrary': True, 'updeateGoodreadsProgress': False}}
DEBUG:  200.6 get_prefs - start - store_name='storeOptionsStore'
DEBUG:  200.6 get_plugin_pref - start - store_name='commonOptionsStore', option='individualDeviceOptions'
DEBUG:  200.6 get_prefs - start - store_name='backupOptionsStore'
DEBUG:  200.6 get_prefs - start - store_name='updateOptionsStore'
DEBUG:  200.6 _get_selected_ids - self.gui.current_view().model() <calibre.gui2.library.models.BooksModel object at 0x000002926C4258B0>
DEBUG:  200.6 get_column_names - columns_config: {'currentReadingLocationColumn': '#kobobookmark', 'lastReadColumn': '#lastread', 'percentReadColumn': '#percentread', 'ratingColumn': 'rating'}
Actions Chains: Calibre Actions: Finishing run action
debug1: run_check: global_vars: {'_chain_name': 'Restore Device Bookmarks', '_chain_iteration': '1', 'location': 'library', 'selection_count': '1', '_action_name': 'Calibre Actions', '_action_comment': 'Re-upload cover', '_action_index': '2'}
    value: Kobo Aura HD
    is_true: True
Action Chains: Restore Device Bookmarks: starting action No. 3: Calibre Actions
Actions Chains: Calibre Actions: paths > ['KoboUtilities', 'Upload covers for Selected Books']
Actions Chains: Calibre Actions: Found action: &Upload covers for Selected Books
DEBUG:  201.6 Have a Kobo device connected connected
DEBUG:  201.6 BEGIN Get Device Path
DEBUG:  201.6 Root path of device: K:\
DEBUG:  201.6 END Get Device Path
DEBUG:  201.6 KoboUtilities:get_device - self.device_path="K:\"
DEBUG:  201.6 KoboUtilities:get_device - drive_info: {'main': {'device_store_uuid': '97dc9975-085a-4dc5-a7f4-a614689983f3', 'device_name': 'Kobo Aura HD', 'prefix': 'K:/', 'date_last_connected': '2020-12-26T22:44:05.310516+00:00', 'location_code': 'main', 'last_library_uuid': 'b96decbc-fcca-470f-b7af-8e1338a26310', 'calibre_version': '5.8.1'}}
DEBUG:  201.6 migrate_library_config_if_required - start
DEBUG:  201.6 get_library_config - library_config: {'SchemaVersion': 0.1, 'profiles': {'Kobo Aura HD': {'customColumnOptions': {'currentReadingLocationColumn': '#kobobookmark', 'lastReadColumn': '#lastread', 'percentReadColumn': '#percentread', 'ratingColumn': 'rating'}, 'forDevice': '97dc9975-085a-4dc5-a7f4-a614689983f3', 'profileName': 'Kobo Aura HD', 'storeOptionsStore': {'storeOnConnect': False, 'promptToStore': False, 'storeIfMoreRecent': True, 'doNotStoreIfReopened': False}, 'updateOptionsStore': {'doEarlyFirmwareUpdate': False, 'doFirmwareUpdateCheck': False, 'firmwareUpdateCheckLastTime': 0}}}, 'readingPositionChangesStore': {'selectBooksInLibrary': True, 'updeateGoodreadsProgress': False}}
DEBUG:  201.6 get_prefs - start - store_name='storeOptionsStore'
DEBUG:  201.6 get_plugin_pref - start - store_name='commonOptionsStore', option='individualDeviceOptions'
DEBUG:  201.6 get_prefs - start - store_name='backupOptionsStore'
DEBUG:  201.6 get_prefs - start - store_name='updateOptionsStore'
DEBUG:  201.6 _get_selected_ids - self.gui.current_view().model() <calibre.gui2.library.models.BooksModel object at 0x000002926C4258B0>
DEBUG:  201.6 upload_covers - selectedIDs: [3096]
debug1: run_check: global_vars: {'_chain_name': 'Restore Device Bookmarks', '_chain_iteration': '1', 'location': 'library', 'selection_count': '1', '_action_name': 'Single Field Edit', '_action_comment': 'Update #onkobo column', '_action_index': '3'}
    value: Kobo Aura HD
    is_true: True
Action Chains: Restore Device Bookmarks: starting action No. 4: Single Field Edit
Action Chains: chain (Restore Device Bookmarks) finished in: 7.309176445007324
Old 12-26-2020, 07:04 PM   #202
ownedbycats
Custom User Title
Sorry, I decided to split off my conditional post at the same time you posted.
Old 12-26-2020, 07:15 PM   #203
ownedbycats
Custom User Title
Could've been gremlins. I have a particular talent for somehow generating one-off glitches in software.
Well, this time the error's different:
2020.12.26 19:13:22:342 App version: 8.5.2951.1
2020.12.26 19:13:25:509 Unexpected command line parameter: ;D:\Documents\My Books\Jenny Oldfield\Starlight (5627)
2020.12.26 19:13:26:502 Search stopped
(Note that -d "D:\Path1;D:\Path2" does work in command-line, you don't necessarily need to split them apart)
Open:  C:\Program Files\Mythicsoft\Agent Ransack\AgentRansack.exe (file):  ['D:\\Documents\\My Books\\Jenny Oldfield\\Steamboat Charlie (5626)', 'D:\\Documents\\My Books\\Jenny Oldfield\\Starlight (5627)']  (args):  -d mutiple:  True
Action Chains: chain (Search with Agent Ransack) finished in: 0.8465745449066162
I noticed the use of single quotes in the debug log. Not sure if that's being passed along, but Windows uses double-quotes for paths.
Old 12-26-2020, 07:19 PM   #204
ownedbycats
Custom User Title
Some links that may be of assistance:
https://ss64.com/nt/syntax-esc.html
https://www.robvanderwoude.com/escapechars.php
Old 12-26-2020, 07:33 PM   #205
capink
OK, a new version is attached to the same post. It does not change anything, but adds an additional debug statement. Just to know if I am doing something wrong. It should print the whole command.
Old 12-26-2020, 07:51 PM   #206
ownedbycats
Custom User Title
Open:  C:\Program Files\Mythicsoft\Agent Ransack\AgentRansack.exe (file):  ['D:\\Documents\\My Books\\Jenny Oldfield\\Steamboat Charlie (5626)', 'D:\\Documents\\My Books\\Jenny Oldfield\\Starlight (5627)']  (args):  -d mutiple:  True sep:   ;
debug1: cmd: "C:\Program Files\Mythicsoft\Agent Ransack\AgentRansack.exe" -d "D:\Documents\My Books\Jenny Oldfield\Steamboat Charlie (5626)" ;"D:\Documents\My Books\Jenny Oldfield\Starlight (5627)"
Action Chains: chain (Search with Agent Ransack) finished in: 0.7905950546264648
There's a space before the semicolon that's causing it to fail. It works if I remove the space. I wonder how it got in there.
Old 12-26-2020, 07:54 PM   #207
capink
Check the settings box and make sure it has no extra space.
Old 12-26-2020, 07:58 PM   #208
ownedbycats
Custom User Title
There was a space in there. I removed it and it worked!
Old 12-26-2020, 08:03 PM   #209
ownedbycats
Custom User Title
Thank you!
Old 12-28-2020, 05:18 AM   #210
Thasaidon
Hedge Wizard
Thasaidon ought to be getting tired of karma fortunes by now.Thasaidon ought to be getting tired of karma fortunes by now.Thasaidon ought to be getting tired of karma fortunes by now.Thasaidon ought to be getting tired of karma fortunes by now.Thasaidon ought to be getting tired of karma fortunes by now.Thasaidon ought to be getting tired of karma fortunes by now.Thasaidon ought to be getting tired of karma fortunes by now.Thasaidon ought to be getting tired of karma fortunes by now.Thasaidon ought to be getting tired of karma fortunes by now.Thasaidon ought to be getting tired of karma fortunes by now.Thasaidon ought to be getting tired of karma fortunes by now.
Thasaidon's Avatar
Device: Kobo Touch, Nook Simple
Quick Question
Hi
I have been playing with the plugin recently and have been trying to set up a chain that "clicks on" certain icons in Calibre Editor.
I have not yet found a way of doing this. Am I missing something or is it not possible without writing a load of code?
Thasaidon is offline   Reply With Quote
Action Chains Resources capink Plugins 80 09-18-2025 05:45 AM
[Editor Plugin] Editor Chains capink Plugins 106 06-17-2025 06:36 PM
[GUI Plugin] Noosfere_util, a companion plugin to noosfere DB lrpirlet Plugins 2 08-18-2022 04:15 PM
