#4321 |
![]() Posts: 5
Device: Android and PC
[QUOTE=JimmXinu;4012672]Network errors like usually indicate that you are being blocked or throttled somewhere.
.../QUOTE] Looks like you are right. If i change my ISP from Cable to Mobile Hotspot than it works like a charm. The old standalone FanFictionDownloader works with my cable provider, I think i´ll use this tool for new ebooks than. |
#4322 | |
Custom User Title
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 11,444
![]() Question: For a story with a URL-specific section, I just noticed that my main set of replace_metadatas (site and tagcategory) aren't working on it after an update. I tried copying the relevant ones down to that URL section like so: Code:
[https://archiveofourown.org/works/21814324] never_make_cover:true replace_metadata: site=>archiveofourown.org=>Archive of Our Own tagscategory=>^(.*)$=>Fanfiction.\1 tagscategory=>(Mass Effect: Andromeda|Mass Effect Trilogy)=>Mass Effect ## This fic has non-breaking spaces which look weird in description, this removes them add_to_replace_metadata_filelist:file:///D:/Documents/Miscellany/ReplaceNBSP.txt Last edited by ownedbycats; 07-17-2020 at 01:38 PM. |
#4323 |
![]() Posts: 51
I'm trying out the new site scribblehub.com and have run into a few minor problems.
First, I can't seem to get story URLs from web page. I get an error. The error code for https://www.scribblehub.com/genre/action/ below. Spoiler:
Second is that it is inconstant about getting the cover image from the story. These stories don't have cover images picked up. https://www.scribblehub.com/series/5...emists-potion/ https://www.scribblehub.com/series/43804/pellan-rise/ https://www.scribblehub.com/series/43812/kammi-kettu/ https://www.scribblehub.com/series/40636/falling-over/ https://www.scribblehub.com/series/51069/deviled-egg/ While these stories have the cover image picked up just fine. https://www.scribblehub.com/series/7...tch-of-chains/ https://www.scribblehub.com/series/8...n-of-avonside/ https://www.scribblehub.com/series/5...le-with-horns/ |
#4324 | |
Plugin Developer
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 7,220
See https://github.com/JimmXinu/FanFicFare/wiki/INI-File Or, possibly, you've bumped into another bug or limitation in your apparent quest to venture into every corner case in the system. |
#4325 | |
Plugin Developer
The server is declining to give us that page. Changing user_agent doesn't appear to help. I honestly find it more surprising that story download works when other pages are blocked like that.I've alerted mavi0 to the cover issue. |
#4326 | |
Custom User Title
I'm just very good at breaking things. Finding ways to get out-of-bounds in video game levels is always a fun pastime. Last edited by ownedbycats; 07-17-2020 at 02:28 PM. |
#4327 | |
![]() Posts: 51
I also noticed that there is no rating like Teen, Mature, Adult. Apparently Mature is listed as one of the Genres and isn't being picked up. So their 2 ratings are Mature and Not Mature, and Not Mature is indicated by the lack of the Mature tag.I don't know if anything can be done about that one. Just thought I would bring it up in case mavi0 can work a miracle. |
#4328 |
Plugin Developer
New Test Version Posted
2020-07-17 - Fixes for scribblehub.com - cover, datePublished, rating - Thanks, mavi0! |
#4329 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 124
Device: Kindle Oasis 2
#4330 | |
![]() Posts: 51
The error was "'NoneType' object has no attribute 'find'" It is the only one so far that has that problem, and it didn't do that in the previous version. |
#4331 | |
dev
Device: kindle 2011
I'll submit a pull request with a fix in a mo
#4332 |
![]() Posts: 51
Looks like it was just an edge case. And thank you very much for adding this site.
#4333 |
Plugin Developer
2020-07-17 - (More) Fixes for scribblehub.com - cover, datePublished, rating - Thanks, mavi0! |
#4334 | |
![]() Posts: 51
https://www.scribblehub.com/series/6...laws-of-magic/ https://www.scribblehub.com/series/5...ters-are-yuri/ |
#4335 |
Plugin Developer
2020-07-18 - Fixes for scribblehub.com metadata - datePublished, numWords, averageWords, views - Thanks, mavi0! |
| Tags |
| fanfiction |
| [GUI Plugin] KindleUnpack - The Plugin | DiapDealer | Plugins | 527 | 08-15-2025 02:36 PM |
| [GUI Plugin] Open With | kiwidude | Plugins | 404 | 02-21-2025 06:42 AM |
| [GUI Plugin] Marvin XD | Philantrop | Plugins | 126 | 01-29-2017 01:48 PM |
| [GUI Plugin] KiNotes | -axel- | Plugins | 0 | 07-14-2013 07:39 PM |
| [GUI Plugin] Plugin Updater **Deprecated** | kiwidude | Plugins | 159 | 06-19-2011 01:27 PM |
