Old 01-10-2017, 12:19 PM   #166
Teom@n
Teom@n began at the beginning.
Device: Kindle PW3, Kobo Libra H2O
That depends on your technical skills. If your MS Excel spreadsheet contains only two columns you could save it as a tab-delimited text file and process it with tab2opf.py.
If you're familiar with regular expressions, you could also convert the tab-delimited text file directly using a couple of regular expressions.
I have a computer skills so I will try to do my best.
Teom@n is offline   Reply With Quote
Old 01-10-2017, 02:10 PM   #167
Teom@n
Do you know any script(python, etc.) for converting huge html files to other formats?
Old 01-10-2017, 02:14 PM   #168
Doitsu
Doitsu's Avatar
Device: Kindle PW2
I usually use the Python bs4 library for HTML parsing.
Old 01-10-2017, 03:50 PM   #169
Teom@n
Ok, I will try it. Thanks.
Old 01-22-2017, 02:37 PM   #170
Teom@n
hi,
could you share the script/commands that you were using for converting html to text? I have a html file(124mb) which I took it from a mobi file. I installed the python and beautifulsoap.
could you guide me?
thanks
Old 01-22-2017, 05:26 PM   #171
Doitsu
Doitsu's Avatar
Device: Kindle PW2
Unfortunately, I can't help you with that, because scripts and commands will vary depending on the exact input and output formats. However, BS4 is well documented. For example:
soup.get_text()
will strip all tags from an HTML file.
If you're not a Python programmer, you could also use a text editor with regular expressions support, e.g. Notepad++, to remove unwanted tags or convert them to a different format.
Old 01-23-2017, 04:51 AM   #172
Teom@n
soup.get_text()
Thanks mate.
Old 03-03-2019, 09:06 PM   #173
sayonaroo
sayonaroo began at the beginning.
Device: likebook plus
Could someone make one for me? I cannot figure out how to use python
I wanted to make a kindle dictionary out of the korean-Japanese naver dictionary
http://download.huzheng.org/babylon/japanese/
It says
You can convert any babylon .bgl file to StarDict format by the PyGlossary tool, just visit: http://pyglossary.sourceforge.net
sayonaroo is offline   Reply With Quote
Old 10-17-2019, 10:05 PM   #174
Phionz Paranto
Phionz Paranto began at the beginning.
Device: Kindle Oasis 3
Smile Please the update.
Originally Posted by thomass View Post
why don't you try one to see.
BTW: attached an Indonesian – English dict with ~22300 words (stardict-quick)
I have downloaded and tried this dictionary to see if it works well. I found that this dictionary is very simple and basic for Indonesian-English. Do you have the most updated one? It's 2019 now. Thank you very much.
Phionz Paranto is offline   Reply With Quote
Old 10-17-2019, 11:12 PM   #175
The last time thomass visited Mobileread was a year ago. And yes, it's been 8 years since that dictionary was posted. The advice on how to create your own dictionary is still valid so you may want to apply it. Or if your time is worth more, you might purchase an Indonesian/English dictionary from Amazon. Check Kindle Default Dictionaries Indonesian for example.
Old 03-24-2020, 03:48 PM   #176
markvdvelde
markvdvelde began at the beginning.
Croatian to English
English-Croatian dict:
This is a nice dictionary, but do you have it the other way around, from Croatian to English? When ever I search for Croatian-English dictionaries, I end up trying lots unknown and complicated (at least for me) software that has to run with commands etc. This is the first EN-HR dictionary that works out of the box. I would very happy with HR-EN too.
markvdvelde is offline   Reply With Quote
ebook tools, kindle tools
Dictionary lookup in iBooks 1.1: "Dictionary not available for this language" kjk Apple Devices 71 09-18-2010 06:24 AM
best foreign language & dictionary options? joedevivre Which one should I buy? 2 12-13-2009 09:40 AM
How do I create headword-enabled Mobipocket dictionary? owl123 Kindle Formats 1 07-24-2009 11:13 AM
Useful tip: How to change the BD language AFTER you create a book HarryT Workshop 4 04-15-2009 12:36 AM
creating a foreign language dictionary dirtylc Amazon Kindle 1 03-30-2009 08:40 AM
