Old 12-06-2019, 02:31 AM   #1
tamarissa
tamarissa began at the beginning.
Device: Kobo Aura H2O
Column Built From Other Column Formula Adjustment
I have this formula that I use to put a collection into my eReader from a column, and it works just fine. I get an end result of "R - Tag" or "N - Tag", which is what I want. However, if none of the conditions are met, I just get an R or N (which is also technically correct, but I'd prefer if it just stayed blank if that's the case). Is there a way to make it so that the field remains blank if there are no matching tag criteria?
{#read_status:}{:'list_item(list_intersection(field("tag"),sublist("Tag  1,Tag 2,Tag 3,",0,0,","), ","),0,",")'| - |}
tamarissa is offline   Reply With Quote
Old 12-06-2019, 06:15 AM   #2
chaley
This should do it assuming I understand your requirements, specifically that the R or N appears only when there is a matching tag.
program:
	x=list_item(
		list_intersection(
			field("tag"),
			"Tag 1,Tag 2, Tag 3",
		0,",");
	test(x, strcat(field('#mybool'), ' - ', x), '')
Note that you don't need to explicitly create a list (your use of sublist). A string of SEPARATOR-separated values works.
Old 12-07-2019, 02:18 AM   #3
tamarissa
Yes, it sounds like you are understanding what I'm after, but I just tried your suggestion, and unfortunately, it didn't work for me... This is what the template tester said was wrong:
EXCEPTION: Value: unknown field #mybool
Name:	Screen Shot 2019-12-06 at 11.13.55 PM.png
Old 12-07-2019, 05:21 AM   #4
those were placeholder names for custom field TYPES
change the #mybool to the name of your Boolean field's (Y/N) name
Old 12-07-2019, 05:27 AM   #5
chaley
This is correct. I didn't have a column #read_status so I used #mybool instead to test it.
Old 12-07-2019, 02:19 PM   #6
tamarissa
Ah, I see... worked perfectly once I changed it to my '#read_status'. Thanks so much for your help!
Custom column built from word count column Montana Harper Library Management 3 10-04-2018 10:57 PM
Column built from other column : Mark read if evaluated Cmely Library Management 1 02-26-2017 10:07 AM
Yes/No column built from other columns barlowrm Calibre 5 11-17-2016 03:34 PM
Tags Column - Left Alignment not maintaining adjustment crissman Calibre 7 02-20-2015 11:49 PM
Custom yes/no column built from long text column Philantrop Library Management 7 03-23-2013 08:44 PM
