Fetch annotations plugin
The fetch annotations plugin doesn't seem to be working properly. When I right-click on the book I'd like the annotations for, it grabs me a txt file of bookmarks from 2 different e-books. This is a PDF I've downloaded and made a bunch of highlights in, that I need for research for a school paper. Does anyone know how I can fix this?
Thank you! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 24,905
Are you referring to the "Annotations" plugin, or the "Fetch annotations" function that is on the menu of the "Send to device" button? I can't help with the latter.
If it is the Annotations plugin, it should be working. For a Kindle, it has to match what s in the clippings file with the books and then prompt to confirm which book the annotations belong to. If this isn't correct, then I need to see a debug log to try an work out what is going wrong. Run calibre in debug mode (right click on the preferences button and select "Restart in debug mode"), fetch the annotations an post the log in the Annotations plugin thread. |
![]() Posts: 21
Device: Kindle 2. Gen
I did a run in the debug mode. This is the result. I hope you find something useful.
| Tags |
| annotations, fetch, plugin, support |
| Fetch Annotations not working | leefa | Calibre | 10 | 01-14-2013 04:51 PM |
| Fetch Annotations - where in Calibre version are they? | Lynx-lynx | Library Management | 8 | 01-02-2013 07:40 AM |
| 0.8.22 not suporting Fetch Annotations ? | pchrist7 | Calibre | 8 | 10-22-2011 01:10 PM |
| Fetch Annotations | atjnjk | Calibre | 2 | 01-23-2011 10:59 PM |
| Fetch Annotations does not work with K3 | enigma2k | Calibre | 5 | 09-23-2010 11:26 AM |
