#271 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 80,727
#272 |
![]() Posts: 145
Device: Kobo Glo; Kobo Libra
Conversion order
I import a mobi file into Calibre and converted it into an epub file. I edit that epub. But when I create the kepub file I get a conversion from the mobi file. I had to delete the mobi file to convert from the epub. What did I do wrong ? |
#273 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 691
Device: BeBook 1, BeBook Pure, Kobo Glo, (and HD),Energy Sistem EReader Pro +
When you bring up the "convert" dialogue, change the "Input Format" (top left) from "Mobi" to "Epub"
BobC |
#274 |
![]() Posts: 19
Device: Kobo Aura H2O
editing kepubs
I'm not sure what's possible through the Calibre plugin API, but I wonder if it's possible to add kepub to the list of formats that the eBook Editor accepts? It would be really helpful to be able to edit the kepub directly from Calibre *as* a kepub, without having to edit it as an epub and then rename it...
In particular because I'd quite like to maintain separate epub and kepub formats for different devices... |
#275 |
Generally Awesome Person
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,100
Device: Kobo Clara HD, Kindle Oasis
I'm (kinda) back. I've migrated to BitBucket, while I was doing that I did some cleanup and some minor bugfixes. Version 3.0.0 is posted now.
There's also some new translation strings, so anyone who speaks something other than English please go translate text into other languages. |
#276 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,083
Device: Kobo Clara 2E, Tolino Shine 3
I'm not back, but coming from installing the new version, and just would like to report that the issue that I have noticed in post #194 ff. now is off!
Still no idea what is has been, but I'm lucky to have it working properly by now. Thank you, Joel, great work!! |
#277 |
![]() Posts: 4
Device: Kobo Aura One
Hi!
I would love te use this plug-in but I cannot. I read ebooks in French and there is a character named "espace fine" (small space?) That character is displayed by an unknown character like "?" or a square . I don't know if the unsecable space is correctly displayed.Could it be possible to correct this display?*It would be very nice to read books with great display .Thank you very much! |
#278 |
Upload both the source ePub and the converted KePub to https://www.dropbox.com/request/IbA73zsqFLdmWFYdyLtk and I'll take a look when I get a chance. It would help greatly if you have a sentence I can search for (exactly as it appears in the book) to find the problem faster.
#279 |
![]() Posts: 4
I have just uploaded them. You will find "espaces fines" before those characters: ?, !, :, ;.
Several sentences in the book: –*"Je peux avoir votre nom" – "un franc-tireur à la renommée mondiale" Unbreakable spaces can be found before "»" and after "«" for instance. I really hope you will be able to add this feature! Thank you for the help. |
#280 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 24,905
The "espaces fines" appears to be Unicode U+202F which is "NARROW NO-BREAK SPACE". This does work on my devices with any of the built-in fonts. I can't see the book you uploaded, but the attached sample book works correctly when sent using the extended driver, this plugin or as an epub. The book displays a lot of different characters to see if the font selected on the device supports them, plus a lot of other tests. I added all the different spaces I could quickly see at the end of the first chapter. None show as the invalid character for any of the fonts on my Kobo devices. |
#281 |
![]() Posts: 4
I use Adobe Garamond Pro font. But it does the same with every font.
You can see the screen of kepub and ePub in different fonts in the attached files. As you can see, narrow no-break space works on ePub and does not work with kepub with the same fonts. ![]() EDIT: I cannot upload files. Last edited by Thoris; 11-14-2017 at 08:52 AM. Reason: Forgot attached files |
#282 |
I'll take a look at the books you uploaded when I get a chance. Please understand this is something I'm doing in spare time, which two small children don't leave a lot of, so it probably won't be today but I will look at it.
#283 |
![]() Posts: 4
Thank you!
Don’t worry I do not want you to hurry up for me, I really actually understand |
#284 |
Whatever this is, it's not the plugin. I took the books you gave me, found the espace fine (Unicode 0x202F, "NARROW NO-BREAK SPACE"). It's correct in the converted KePub file. There's two possibilities I see: it's a font issue or it's the rendering engine (Kobo uses the Adobe RMSDK renderer for ePub files but the NetFront ACCESS embedded browser for KePub files).
I'm not sure exactly how likely either one is since it's working fine in another book. Maybe take the font sampler davidfor posted and see how that works for you. You can use this plugin or the KoboTouchExtended driver, it's the same code to convert the books. Last edited by jgoguen; 11-19-2017 at 03:37 PM. |
#285 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 6,267
Just to add a bit more info regarding "special spaces"and davidfor's font tester epub ...
I often use Adobe Garamond as a sideloaded font on my Kobos so I had a look inside the Regular ttf file. As far as I can tell this font does not actually contain the glyphs for any of these enSpace (u2002), emSpace (u2003), thinSpace (u2009), hairSpace (u200A) or narrowNBSP (u202F). Kepub: Seems to display characters enSpace and emSpace OK, but the other 3 display as a cross-in-a-box. I'm guessing the kepub reading app is finding the first 2 in one of the other (built-in???) fonts and falling back to them. (It's hard to be sure with spaces which have no distinguishing features ) The last 3 presumably don't occur in any of the fonts being used for fallback.I had success displaying all 6 "special spaces" with fonts like Times New Roman, Charis SIL, Bookerly and Linux Libertine G. All of these contain all 6 glyphs without needing to fallback to some other device font. Epub: I only tested standard epub briefly but it did seem to correctly display all 6 spaces. Even with Adobe Garamond which doesn't actually contain 5 of the glyphs. I have no idea how the Adobe reading app is "finding", or maybe constructing, the missing glyphs. Last edited by jackie_w; 11-19-2017 at 03:18 PM. |
| catalogue builder output columns are not in the same order in the output | KWhytte | Library Management | 5 | 12-04-2012 02:03 AM |
| Plugin not customizable: Plugin: HTML Output does not need customization | flyingfoxlee | Conversion | 2 | 02-24-2012 02:24 AM |
| Plugin which uses net as input and output | medve | Development | 0 | 12-04-2011 03:20 PM |
| Creat new Output plugin (LaTeX and/or txt2tags) | Lebewesen | Development | 3 | 11-22-2011 11:10 AM |
| AZW Conversion Output Plugin | tylau0 | Plugins | 59 | 08-14-2011 10:36 PM |
