Old 05-07-2016, 01:38 PM   #1
evanft
evanft ought to be getting tired of karma fortunes by now.evanft ought to be getting tired of karma fortunes by now.evanft ought to be getting tired of karma fortunes by now.evanft ought to be getting tired of karma fortunes by now.evanft ought to be getting tired of karma fortunes by now.evanft ought to be getting tired of karma fortunes by now.evanft ought to be getting tired of karma fortunes by now.evanft ought to be getting tired of karma fortunes by now.evanft ought to be getting tired of karma fortunes by now.evanft ought to be getting tired of karma fortunes by now.evanft ought to be getting tired of karma fortunes by now.
Device: Kindle 4 NT
Disable front light completely?
Is there a way to completely disable the front light on the KV? I'm coming from a K4NT and I'm getting eye strain even with the light at the lowest setting.
I'm already jailbroken on FW 5.6.5.
evanft is offline   Reply With Quote
Old 05-07-2016, 02:02 PM   #2
HarryT
HarryT's Avatar
Presumably you're reading in low light if you have the frontlight on its lowest level. Won't turning it off completely cause even more eye strain? The screen will be more difficult to read without any light!
Old 05-07-2016, 03:31 PM   #3
evanft
Device: Kindle 4 NT
Having the light on any level hurts my eyes, period. I want it off completely.
Old 05-07-2016, 04:01 PM   #4
trade it in on a model without a front light
Old 05-07-2016, 04:05 PM   #5
evanft
Device: Kindle 4 NT
That seems the best course of action. I'm just going to keep my K4NT.
Old 05-07-2016, 04:14 PM   #6
Barbara1955
Non-Techy
Barbara1955 ought to be getting tired of karma fortunes by now.Barbara1955 ought to be getting tired of karma fortunes by now.Barbara1955 ought to be getting tired of karma fortunes by now.Barbara1955 ought to be getting tired of karma fortunes by now.Barbara1955 ought to be getting tired of karma fortunes by now.Barbara1955 ought to be getting tired of karma fortunes by now.Barbara1955 ought to be getting tired of karma fortunes by now.Barbara1955 ought to be getting tired of karma fortunes by now.Barbara1955 ought to be getting tired of karma fortunes by now.Barbara1955 ought to be getting tired of karma fortunes by now.Barbara1955 ought to be getting tired of karma fortunes by now.
Barbara1955's Avatar
Device: Samsung Cell Phone & Amazon Fires & Kobo eReaders
I get eye strain at the Lowest setting even in Bright sunlight. My eyes more comfortable hat higher settings. Try increasing the light see what happens.
Barbara1955 is offline   Reply With Quote
Old 05-08-2016, 05:35 PM   #7
eschwartz
Ex-Helpdesk Junkie
eschwartz's Avatar
Since you are jailbroken, you should be able to disable the frontlight using peterson's Front Light Master extension.
(It is possible the method used to control the frontlight needs to be updated for KV compatibility. Either way, the current extension should certainly give you an idea of what might need doing.)
Old 05-09-2016, 10:56 AM   #8
geekmaster
Carpe diem, c'est la vie.
geekmaster's Avatar
Device: K1 to PW3
You can turn it off completely with a KUAL script (not written yet AFAIK). I was turning off the LED from root shell over SSH on my PW1 back before I lost it on a trip. I have a functional PW3 now, so I can explore making such a KUAL extension...
Hmm... I just realized I can probably modulate (baseband AM, or at least PWM) the backlight for audio output for my kindle video player. A photocell connected to amplified speakers should work for that. I may need to build a kernel module for such add-on audio support for mute kindles like the paperwhite (or K4 with modulated power LED) models.
Old 05-09-2016, 11:38 AM   #9
eschwartz
Ex-Helpdesk Junkie
eschwartz's Avatar
@geekmaster,
Like I said, peterson already made one.
As I don't own any frontlit Kindle, I don't know whether they all share the same sysfs controls or need to be updated for different models.
Old 05-12-2016, 02:57 PM   #10
Yourcat
Yourcat knows the way to San Jose.Yourcat knows the way to San Jose.Yourcat knows the way to San Jose.Yourcat knows the way to San Jose.Yourcat knows the way to San Jose.Yourcat knows the way to San Jose.Yourcat knows the way to San Jose.Yourcat knows the way to San Jose.Yourcat knows the way to San Jose.Yourcat knows the way to San Jose.Yourcat knows the way to San Jose.
Device: PW3 5.6.5-usbnet
The orange and green LEDs would may stereo "playback" if you enjoy PWM.
Yourcat is offline   Reply With Quote
Old 05-12-2016, 03:07 PM   #11
Yourcat
With usbnet you may check whether https://www.mobileread.com/forums/sho...68&postcount=4 works for the KV.
Adding this to the suspend or wake-up event script should be acceptable instead of a Kual menu. Starting reading one may need to increase/change the brightness anyway.
Old 05-12-2016, 07:40 PM   #12
The pathname may have changed if running 5.7.x but all 5.6.x should have the same as shown.
Old 05-12-2016, 08:26 PM   #13
AFAIR, we're successfully using that path in KOReader for the whole Wario range .
And I can attest that it still holds true on my PW2 on 5.7.x.
Old 05-12-2016, 09:30 PM   #14
The /sys tree is **supposed to be** a stable interface (for a kernel Major.Minor version series).
But those provided by modules outside of the mainstream Kernel (think: Amazon/Lab126 authored) might not reach that goal.
So I was just being careful with my 'check it before using it' advice.
Old 07-12-2017, 08:15 AM   #15
AnimalOfArt
AnimalOfArt ought to be getting tired of karma fortunes by now.AnimalOfArt ought to be getting tired of karma fortunes by now.AnimalOfArt ought to be getting tired of karma fortunes by now.AnimalOfArt ought to be getting tired of karma fortunes by now.AnimalOfArt ought to be getting tired of karma fortunes by now.AnimalOfArt ought to be getting tired of karma fortunes by now.AnimalOfArt ought to be getting tired of karma fortunes by now.AnimalOfArt ought to be getting tired of karma fortunes by now.AnimalOfArt ought to be getting tired of karma fortunes by now.AnimalOfArt ought to be getting tired of karma fortunes by now.AnimalOfArt ought to be getting tired of karma fortunes by now.
AnimalOfArt's Avatar
Device: changing frequently
I used the extension as it is on KV and it works!
AnimalOfArt is offline   Reply With Quote
Is it possible to disable the front light? (T68) cicabum Onyx Boox 0 06-11-2015 04:30 PM
Completely disable system status bar on T68 pickyaxe Onyx Boox 4 02-09-2015 03:06 PM
How to completely disable subscription? Smartie Feedback 3 06-06-2014 01:37 PM
Turn off PW light completely gers1978 Kindle Developer's Corner 11 12-13-2012 03:59 PM
Completely disable auto correct ? markkenzy Amazon Fire 4 12-24-2011 08:27 PM
