#2161 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 250
Device: Kobo Aura
This may have been asked before, but I was unable to find it via searching.
Just wondering, in koreader is it possible to double tap or something to make images in epubs larger/full size? I tried but it doesn't work for me..
#2162 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 4,466
For me, the images that I would like to see enlarged from .epubs, would most often be maps, of fantasy geography. One thing I can do is extract the wanted image files from the .epub (it is just a .zip file) and use Gimp2 to size them for full screen display on my AuraHD. If I have looked at them and have them in the "History", along with my current read, I can leave off reading and call up the History and select the map I want from those I have in History. Then I can select my current read entry in History and return right back where I left off. For some stories you can download better maps off the internet. The History can be a very handy way to move between various ebooks and image files. It might be an interesting feature for Koreader, if there were generated from .epubs a "History" like "Illustrations" function/menu item. Any useable image file could be found within the .epub file and listed. Naming them, could be an issue, but would not be critical. The image files would have to filtered by size to eliminate "Drop caps" and such. Maybe a longpress option could be to "Make this the Sleep image". Luck; Ken Last edited by Ken Maltby; 04-30-2015 at 01:19 PM. |
#2163 |
Device: Kobo Aura
That's a good idea. For me I have some training material in epub from work, and some of the screen shots of programs would be nice to make larger, it even says at the beginning of epub to double tap images to make bigger, but unfortunately it doesn't work in Koreader.
#2164 | |
Open defaults.lua script file in the free "Notepad++" and scroll down to: -- gesture detector defaults DGESDETECT_DISABLE_DOUBLE_TAP = true and change the true to false. Who knows it might work. Luck; Ken |
#2165 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,379
Device: Kindle Paperwhite, Kobo Mini
No, it won't.
In order to enforce such behaviour, an EPUB would have to contain active content like JavaScript. However, I don't think any API for that JS has ever been standardized. There seem to exist readers with proprietary APIs, probably most using whatever the browser engine (*cough*webkit*cough*) offers. That said, CREngine, which koreader uses, has no notion of active content. Ebooks can't tell the reader how to behave. |
#2166 |
Since Koreader lets you provide an image that you can have displayed when you place the device in suspend/sleep mode, and it is just a flick of the power switch to call that image up and dismiss it, that might be an even better way to have an often referenced image available.
You could name the image file Sleep_pic and overwrite it with the "Sleep_pic" for your current book. Luck; Ken |
#2167 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,626
Device: Kobo Clara BW
Hi
After some months without trying Koreader (github is not well received everywhere), I tried the latest nightly (30.04) on my Kobo Glo. There have been some nice progresses. Here are two wishes: 1. - Adjusting font-weight I still miss the possibility to use a slightly darker font for reading. I tried side-loading some Kindle fonts (the difference with normal ones is that they look nearly like semi-bold on Linux) but they just appear like normal ones on Koreader. Is there any hope that Koreader one day implement such a feature? On my Kobo eReader.conf file (v. 2.8.1.), I can read Spoiler:
In Koreader, there is no default setting for font-weight that we can adjust, and, I think this kind of feature is missed to allow a comfortable reading. 2. - .lua files Koreader creates a new .lua configuration file for each new book and puts it in a new folder on KoboeReader. Visually, it quickly takes a lot of place. Would it be possible to stack all these new .lua files in a single folder? Last edited by roger64; 05-04-2015 at 02:52 AM. |
#2168 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 13,507
@roger64:
1. Isn't there a 'contrast' setting in the wheel (or B, actually, cf. Ken's answer ) bottom menu? (Or is that only in PDF? Away from a device at the moment).2. IIRC, it does both, there's the sidecar folder, and a global one somewhere in Koreader's main directory. Last edited by NiLuJe; 05-04-2015 at 12:32 PM. |
#2169 | |
In the Kobo Start Menu 7 there is, under "Tools", a "koreader diverse.msh" which has a script "delete dead history entries.sh", that might meet your needs. (I have my external uSD card mounted as read/write, and the script says it doesn't try to delete those with a mnt/sd location, so I just delete them myself.) To be able to write to and delete from your external drive, including using the File Manager's long press options for deleting files, the mnt/sd must be remounted as read/write. To do so I add this to the koreader.sh file, just before "reader.lua" is called: #remount SD card as read/write mount -o remount,rw /mnt/sd Luck; Ken |
#2170 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,489
Device: kobo touch
The reason why "delete dead history entries.sh" does not affect history-files that refer to books on the external sd, is that it cannot decide whether a book has actually been remove from the currently inserted external sd or maybe lives on another sd card (for instance, when you are switching between several sd cards). Last edited by tshering; 05-04-2015 at 12:50 PM. |
#2171 |
Thank for your replies and informations.
font-weight The settings under B do not seem to be apprporiate. The first control switches a regular font to a semi-bold - or more - font -weight which is way too strong for a sustained reading (for me). The second one (contrast) improves slightly the display but not the weight. lua files I will put the "deleteSDRsOnboard" to "true".
#2172 | ||
It's under the "add item" selection, in "[Koreader]". Quote:
Luck; Ken Last edited by Ken Maltby; 05-04-2015 at 02:05 PM. |
#2173 | |
DCREREADER_CONFIG_DARKER_FONT_GAMMA = 25 DCREREADER_CONFIG_LIGHTER_FONT_GAMMA = 10 and DCREREADER_CONFIG_DEFAULT_FONT_GAMMA = 15 (In my case) But remember that the reader settings are only one of a number of factors that can effect how the text gets displayed. Luck; Ken Last edited by Ken Maltby; 05-04-2015 at 02:26 PM. |
#2174 |
@Ken Maltby
Thanks for your informations. On my version of koreader, this file is named "defaults.lua". Following your advice, I modified the settings (gamma to 35 for default...). It did improve somewhat the sharpness of the font and - for me - the quality of reading. It's still not on a par with the kind of emboldening we can get this way. But it looks like it's a trade secret. |
#2175 | |
Luck; Ken |
| KOReader: a document reader for PDF, DJVU, EPUB, FB2, HTML, ... (GPLv3) | hawhill | Kindle Developer's Corner | 1289 | 04-07-2025 11:18 AM |
| Touch Using two Kobos | tkavan | Kobo Reader | 4 | 06-23-2017 03:47 AM |
| 2 kobos at once | tsarinaerika | Kobo Reader | 14 | 06-03-2013 05:13 AM |
| Syncing between two Kobos | fx3000se | Kobo Reader | 4 | 01-24-2013 03:10 PM |
| 2 kobos 1 account | retired05 | Kobo Reader | 9 | 05-05-2012 09:25 AM |
