Old 04-23-2013, 09:01 AM   #16
Pookeysgirl
Pookeysgirl ought to be getting tired of karma fortunes by now.Pookeysgirl ought to be getting tired of karma fortunes by now.Pookeysgirl ought to be getting tired of karma fortunes by now.Pookeysgirl ought to be getting tired of karma fortunes by now.Pookeysgirl ought to be getting tired of karma fortunes by now.Pookeysgirl ought to be getting tired of karma fortunes by now.Pookeysgirl ought to be getting tired of karma fortunes by now.Pookeysgirl ought to be getting tired of karma fortunes by now.Pookeysgirl ought to be getting tired of karma fortunes by now.Pookeysgirl ought to be getting tired of karma fortunes by now.Pookeysgirl ought to be getting tired of karma fortunes by now.
Device: K3, Kobo Mini
Originally Posted by crich70 View Post
You might want to invest in one of these. Mine came with my original K3 and it works perfectly well with the PW as well so it can be used to charge both.
Adaptor for Kindle
I agree. Charging through the computer takes way too long (and I have had a lot of issues not getting a full charge after hours and hours of it being plugged into the computer). I charge my kindle using my blackberry/samsung wall charger, it takes around 2-3 hours and it's full and lasts weeks.
Pookeysgirl is offline   Reply With Quote
Old 04-23-2013, 09:30 AM   #17
crich70
crich70's Avatar
There is also the problem of making sure both ends of the USB cable are plugged in. The adapter solves that problem since one end plugs into the Kindle and the other into a wall socket. If on the other hand you plug into your computer via a usb connection and accidentally unplug it from the computer (or a cat does by pulling on it as I imagine some do) then you're trying to charge it without it being plugged into the source of power. And with the Adapter it only takes a few short hours for the Kindle to be back at full charge.
Old 04-23-2013, 02:27 PM   #18
Pookeysgirl
One of my Kindle Keyboard's won't update to 3.3 gers1978 Amazon Kindle 4 06-07-2012 03:23 PM
Kindle Fire won't charge wyndslash Amazon Fire 12 05-16-2012 03:24 AM
K3 sometimes won't charge terencek Amazon Kindle 16 04-09-2012 06:30 PM
Troubleshooting Kindle 3 won't charge through when connected to computer Pookeysgirl Amazon Kindle 7 02-15-2012 01:50 PM
Won't Charge Drezin Sony Reader 17 07-24-2009 05:32 PM
