![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 691
Device: BeBook 1, BeBook Pure, Kobo Glo, (and HD),Energy Sistem EReader Pro +
After a lot of headscratching I have now found that it's possible to have a Book Title that prevents the book from being opened on the Glo.
My problem came with Charles Kinglsey's book - Westward Ho! I eventually realised that it was the title that stopped me from being able to display a kepubised version of the book. Removing the ! solved it. I suspect that the real issue here is that the book title is used to generate the file name and although it is possible to include the ! in the filename for some reason the Kobo viewer chokes on it and won't open it although the cover page displays perfectly. There may be other characters that give the same effect, it's a matter of being aware. BobC |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,775
Device: Kobo Touch, Glo, Clara HD
Good find. Thanks for sharing.
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 50,774
Regards, David |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 24,905
I had a play and the exclamation mark only causes issues for kepubs. The fix in the driver is simple. I've reported an issue on Joel's driver with the fix.
#5 | |
BobC |
Generally Awesome Person
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,100
Device: Kobo Clara HD, Kindle Oasis
New version pushed up to Github, enjoy!
That certainly solved the issue with the bang. I now seem to have hit the same problem with one of Victor Hugo's books - Les Misérables. Get rid of the accent and change the title to Le Miserables and all is fine.
It appears the Kobo viewer is unhappy with accented characters - at least it doesn't give up on apostrophes though like a reader I have used in the past. I have my books on an SD card and the accented version does display correctly in the bookshelf along with its cover but when you try to open it that's when the error messages occur. BobC |
What OS are you running? I have Les Misérables in my library and despite the title being "Les Misérables" the file system name is "Les Miserables". It gets transferred to my Glo without the 'é' as well. I wonder if that's yet another Windows oddity?
Did I ever mention how much I hate Windows? EDIT: To be clear, I have Windows running and calibre does not save books with accented characters. |
I obviously jumped to a conclusion without full investigation. I'm running XP and I now cannot re-create the original problem.
I had made the assumption because changing the title had given me a usable copy and all the symptoms were the same as with "Westward Ho !". I have changed the Title back to use the accented "e" and re-built the EPUB, transferred that and everything works. As you say the filesystem name, both in windows and on the Glo uses unaccented characters. There must have been some other problem with the original file that triggered the error but as I have now done a couple of edits to it (I think mainly to the metadata and updated in Calibre rather than a clean-up using Sigil but can't honestly be certain) I doubt if I will ever discover what the problem was. Thanks for setting me back on the right track - I did think it a bit odd that the accented problem had caused a problem and not been noted before. BobC |
| Tags |
| filenames |
| Changing a book title - a minor problem | Berzelius | Calibre | 10 | 03-21-2012 12:35 PM |
| PRS-900 SONY PRS900 for Chinese - problem with book title | poi | Sony Reader Dev Corner | 6 | 03-11-2011 01:03 PM |
| PRS-950 SONY PRS950 for Chinese - problem with book title | jessie102 | Sony Reader Dev Corner | 10 | 03-10-2011 12:58 PM |
| SONY PRS900 for Chinese - problem with book title | poi | Introduce Yourself | 6 | 10-10-2010 10:35 PM |
| FB2 Book Title Display Problem | EZ_User | Astak EZReader | 0 | 12-09-2009 12:04 PM |
