Old 04-02-2013, 02:45 PM   #1
yucca
yucca began at the beginning.
Device: Bookeen Cybook Muse Frontlight
Sigil translations: how to generate .qm from .ts?
I started creating a translation of Sigil UI using the recommended way, using Web Tools at https://www.transifex.net/projects/p/sigil/ and it seems to be smooth sailing except for one crucial thing:
The tool generates a .ts file, which seems to be a simple XML file. But Sigil apparently expects .qm files (at least that’s what the
translations
folder contains), which are presumable compressed binary files. So how do I get convert .ts to .qm, or otherwise test my translation in Sigil? (Just in case it matters, I’m using Windows 7.)
yucca is offline   Reply With Quote
Old 04-04-2013, 10:24 PM   #2
user_none
Sigil & calibre developer
user_none ought to be getting tired of karma fortunes by now.user_none ought to be getting tired of karma fortunes by now.user_none ought to be getting tired of karma fortunes by now.user_none ought to be getting tired of karma fortunes by now.user_none ought to be getting tired of karma fortunes by now.user_none ought to be getting tired of karma fortunes by now.user_none ought to be getting tired of karma fortunes by now.user_none ought to be getting tired of karma fortunes by now.user_none ought to be getting tired of karma fortunes by now.user_none ought to be getting tired of karma fortunes by now.user_none ought to be getting tired of karma fortunes by now.
user_none's Avatar
Device: Nook STR
Use lrelease which is part of Qt.
lrelease file.ts
user_none is offline   Reply With Quote
Old 04-05-2013, 01:15 AM   #3
Arios
A curiosus lector!
Arios ought to be getting tired of karma fortunes by now.Arios ought to be getting tired of karma fortunes by now.Arios ought to be getting tired of karma fortunes by now.Arios ought to be getting tired of karma fortunes by now.Arios ought to be getting tired of karma fortunes by now.Arios ought to be getting tired of karma fortunes by now.Arios ought to be getting tired of karma fortunes by now.Arios ought to be getting tired of karma fortunes by now.Arios ought to be getting tired of karma fortunes by now.Arios ought to be getting tired of karma fortunes by now.Arios ought to be getting tired of karma fortunes by now.
Arios's Avatar
Device: Sony PRS-T1, Kobo Touch
user_none, to do it, the whole Qt framework (480 mb) must be installed, is it not?
Arios is offline   Reply With Quote
Old 04-05-2013, 09:05 PM   #4
user_none
user_none's Avatar
Device: Nook STR
lrelease is included with the full Qt binary installation. However, there may be third parties who have packaged the tool (and other transaction tools) separately.
Old 04-09-2013, 04:19 PM   #5
yucca
Disappointed
So this is it? What is the point of having a simple web interface when you need to work locally with a large package anyway?
It’s also unclear to me what happens to the translations after submitting them. Will they eventually become part of the distribution, and how soon? If some software used for that will convert .ts to .qm, why do contributors need to do such conversions themselves if they wish to test the translations locally (as they should)?
Old 04-09-2013, 08:40 PM   #6
user_none
user_none's Avatar
Device: Nook STR
The web interface is so you the transactions can be worked on without having to download anything.
The translation files just like the other source files need to be compiled for use in Sigil itself. Very few people actually compile the files themselves when translating. If you really want to do so then you need the tools to compile the transaction source files.
Translations form the web interface are downloaded and put into the source tree before each release.
Old 04-10-2013, 08:05 AM   #7
yucca
I see. Thanks for the clarification. I wonder if you could add a clarifying note like that into
http://code.google.com/p/sigil/wiki/Translating
It means that the translator needs to know well the user interface, so that he understands, without testing with the translation, where each piece of text will be used. This is manageable, when you know it.
Old 04-10-2013, 05:46 PM   #8
Arios
A curiosus lector!
Arios's Avatar
user_one
yucca has raised out a good point: I also think it is important for translators to see the ts files in the context, to test correctly their ideas. In English, things can be very short, this is not always the same in other languages. We must see if it works (too long, too imprecise?). This is why a small program that would save the ts file to a qm one for testing is a good idea. I found Virtaal (0.7.1) which is cool, but can not export to qm (at least presently).
Anyway, I think the Sigil's translators (and other software that uses the same system, very good by the way) should be able to have this kind of tool without having to download the whole Qt exe.
Have a nice day/evening everyone!
Old 04-10-2013, 10:25 PM   #9
user_none
user_none's Avatar
Device: Nook STR
Again, if you or a third party wants to provide the tool standalone there is nothing stopping you. That said the tools are available as part of Qt.
Translations in de.po lbik Library Management 3 04-14-2013 04:44 AM
Have sigil not generate inline CSS Hellmark Sigil 3 01-27-2012 02:16 PM
UK-US-OZ translations? James_Wilde Writers' Corner 2 12-08-2010 05:49 PM
Copyrights on translations bobcdy General Discussions 5 06-07-2010 10:00 PM
Translations seagull Upload Help 0 03-01-2010 11:47 AM
