Old 09-20-2012, 08:40 PM   #16
And that page is indexed just above the TOC of the master index:
https://wiki.mobileread.com/wiki/Prefix_Index
But I don't think many people find it, even though it is the first link to anything at all.
Does not matter, I am going to use it.
knc1 is offline
Old 09-21-2012, 12:16 AM   #17
stangri
stangri makes transoceanic flights without the assistance of an airplanestangri makes transoceanic flights without the assistance of an airplanestangri makes transoceanic flights without the assistance of an airplanestangri makes transoceanic flights without the assistance of an airplanestangri makes transoceanic flights without the assistance of an airplanestangri makes transoceanic flights without the assistance of an airplanestangri makes transoceanic flights without the assistance of an airplanestangri makes transoceanic flights without the assistance of an airplanestangri makes transoceanic flights without the assistance of an airplanestangri makes transoceanic flights without the assistance of an airplanestangri makes transoceanic flights without the assistance of an airplane
stangri's Avatar
Device: nook
@stangri: Nope, it's really not . What's the beginning of the S/N on your device?
(And, FWIW, the whitelist is deprecated in 0.11.N, and has nothing to do with the lighting up of the 'UYK' link, that's completely handled by the Kindle).
It starts with B006 A0A0. If I'm not using the correct file then which one is?
stangri is offline
Old 09-21-2012, 01:37 AM   #18
@stangri: My bad, it's actually because of the min/target OTA levels. It's just not built to support 3.4, probably because it doesn't, so instead of breaking in unexpected ways in the middle of processing an unknown firmware, it just doesn't even run on unknown firmwares.
You'll have to at least tweak the build scripts, and more likely everything else to actually properly handle fw 3.4.
NiLuJe is offline
Old 09-21-2012, 01:56 AM   #19
stangri
stangri's Avatar
Device: nook
I'm afraid I'm not that proficient, but I would gladly try someone else's script to prepare the 3.4 firmware for the DXG.
If anyone can help, I'd be much obliged.
stangri is offline
Old 09-21-2012, 03:07 AM   #20
stangri
stangri's Avatar
Device: nook
Also, since we're on the subject -- I can't get neither K3 (tried both pre-3.2.1 and 3.2.1) or dxg jailbreak scripts to work on my 3.2.1 ex-demo DXG.
I believe I had jailbroken 3.2.1 on the previous demo DXG (which I've had to send back to the ebay seller because of the small screen defect), but don't remember how.
Any suggestions?
stangri is offline
Old 09-21-2012, 12:36 PM   #21
@stangri: Yifanlu's stuff includes a jailbreak, no need to install it manually.
NiLuJe is offline
Old 10-12-2012, 06:33 PM   #22
horizon21
bookster
horizon21 , Klaatu Barada Niktu!horizon21 , Klaatu Barada Niktu!horizon21 , Klaatu Barada Niktu!horizon21 , Klaatu Barada Niktu!horizon21 , Klaatu Barada Niktu!horizon21 , Klaatu Barada Niktu!horizon21 , Klaatu Barada Niktu!horizon21 , Klaatu Barada Niktu!horizon21 , Klaatu Barada Niktu!horizon21 , Klaatu Barada Niktu!horizon21 , Klaatu Barada Niktu!
horizon21's Avatar
Device: Kindle 3 Wifi+3G
I do not want to open another thread, hence my post in this one. I just updated my kindle 3 to FW 3.4. When I tried to install Niluje's jailbreak ver 0.11.N_k3g, I get an "update failed" message. Why is this happening
horizon21 is offline
Old 10-12-2012, 06:42 PM   #23
qlob
Official Lurker
qlob ought to be getting tired of karma fortunes by now.qlob ought to be getting tired of karma fortunes by now.qlob ought to be getting tired of karma fortunes by now.qlob ought to be getting tired of karma fortunes by now.qlob ought to be getting tired of karma fortunes by now.qlob ought to be getting tired of karma fortunes by now.qlob ought to be getting tired of karma fortunes by now.qlob ought to be getting tired of karma fortunes by now.qlob ought to be getting tired of karma fortunes by now.qlob ought to be getting tired of karma fortunes by now.qlob ought to be getting tired of karma fortunes by now.
qlob's Avatar
Device: Kindle 3.4
what error numbr is it?
qlob is offline
Old 10-12-2012, 06:53 PM   #24
horizon21
bookster
horizon21's Avatar
The error is U004.
EDIT: I think I found the solution in geekmaster's post here:
https://www.mobileread.com/forums/sho...postcount=2614
Old 10-12-2012, 07:21 PM   #25
@horizon21: That quote's conclusion is accurate, but the fix proposed is now deprecated (as of a few hours ago ^^).
I switched the packages (ie. the default one runs on 3.2.1, 3.3 & 3.4). Use the -3.0-to-3.2 one if you're running on an older FW.
NiLuJe is offline
Old 02-21-2016, 03:39 AM   #26
newpain01
newpain01 began at the beginning.
Device: Kindle 3, Kindle PaperWhite 3
Hey guys,
Sorry for posting in this old topic, but my question is related to this topic.
I have a Kindle 3 Keyboard Wifi, Serial number starts with B008 with firmware 3.4.2. I want to jailbreak it so I can use the Kindle Collections Calibre plugin to organise my books in collections (too many books on the device and going through all of them one by one would take too long time).
I have been searching through the forum to fund the correct firmware file to update my device, but no luck. I also checked the mobileread wiki, but no info for the 3.4.x firmware.
https://wiki.mobileread.com/wiki/Kind...26_4.x_Kindles
Can you please provide some information on where I can find the correct image?
Best Regards
newpain01 is offline
Old 02-21-2016, 03:47 AM   #27
eschwartz
Ex-Helpdesk Junkie
eschwartz's Avatar
In the "Font, ScreenSaver & USBNetwork Hacks for Kindle 2.x, 3.x & 4.x" thread which is linked TWICE in that Wiki article.
Moderator Notice
When you tried to post, you should've seen the following warning:
Old Thread Warning
This thread is quite old and may contain outdated information. We recommend that you begin a new discussion if you like to talk about a similar topic. Of course, you may also proceed and reply here.
Please do not perform acts of necromancy on an old thread without a very good reason.
Thread
eschwartz is offline
Hacks Kindle (3) Keyboard : Upgrade and Jailbreak or Jailbreak and Upgrade?? prado Amazon Kindle 3 06-11-2021 10:13 PM
What exactly does the Jailbreak do? hornpipe2 Kindle Developer's Corner 2 01-28-2012 01:38 PM
k3.3 jailbreak ukiman Kindle Developer's Corner 1 01-09-2012 11:05 PM
K3 3.3 Jailbreak mtsp Kindle Developer's Corner 6 11-04-2011 09:26 PM
Help with Jailbreak Xeon43 Kindle Developer's Corner 1 04-29-2011 04:09 AM
