Old 02-26-2012, 08:37 PM   #1
vvvbe
vvvbe can extract oil from cheesevvvbe can extract oil from cheesevvvbe can extract oil from cheesevvvbe can extract oil from cheesevvvbe can extract oil from cheesevvvbe can extract oil from cheesevvvbe can extract oil from cheesevvvbe can extract oil from cheese
Device: PRS-650
Help - Sideload Touch 1.9.14 - Calibre
I have recently moved over to a Kobo Touch from a Sony PRS-650 and always used Calibre to sideload my books.
I recently updated to 1.14 from 1.9. In 1.9 the sideload using Calibre went fine… But now with the update to 1.14 I can not get the reader to see the books from Calibre.
I also tried sideloading using ADE. When I open ADE it shows the books as being there and when I open Kobo in XP it also shows the files as being there. But they are not there when I eject the reader and open library. I have tried DRM books as well as non-DRM. Also, I have not registered this reader with Kobo. Again it worked fine with 1.9.
Is there something I’m missing with the update to 1.14 and sideloading. I have done a search and checked FAQ’s in wiki… Any help would be appreciated… Or if anybody can point me to a MRF thread that would be of help... Thanks!
vvvbe is offline   Reply With Quote
Old 02-26-2012, 10:56 PM   #2
PeterT
I think the issue is not having registered the Kobo.....
Old 02-26-2012, 11:23 PM   #3
vvvbe
Device: PRS-650
Thanks Peter...
So you think that since I updated to 1.14 that I now have to register the reader in order
to sideload from Calibre....
What if I went back to ver. 1.9 do you think I would still have to register... Trying to avoid that and just go with sideloading... But maybe I will have to rethink that... Odd that sideloading worked with the firmware that came with the reader on purchase - 1.9.
Thanks again Peter for you help....
Old 02-27-2012, 01:15 AM   #4
PeterT
I knmow there have been some thread here from other users who did not want or could not register (linux users) and they had found a work around that required the addition of a row to one of the sql tables on the Touch.
Take a look at https://www.mobileread.com/forums/sho...&postcount=262 for some info.
There is a FireFox add on called "SQLite Manager" that can prove useful in editing the SQLlite database on the Touch.
DO TAKE A BACKUP OF IT BEFORE DOING ANYTHING...
With the Kobo mounted it will be in \.kobo\KoboReader.sqlite
Old 02-27-2012, 01:17 AM   #5
PeterT
And yes... there did seem to be a change between the original firmware and newer versions that DID require you to register.
Calibre Kobo sideload wamsaya Devices 2 01-24-2012 04:56 AM
Using Calibre with Kindle Touch or Nook Touch hippiestarr Calibre 8 11-27-2011 08:59 PM
Anyone sideload xfinity? timezone Kindle Fire 5 11-20-2011 03:20 PM
New Kindles - able to sideload/Calibre?? mikel12323 Calibre 7 10-03-2011 05:34 PM
Touch Can I sideload books onto the touch using wifi? scdill Barnes & Noble NOOK 3 06-16-2011 10:50 AM
