![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 42
Device: iPod
Calibre crash after update to 0.8.12
The updated version installed just fine and launched on first run so I decided to go ahead and add a few new books and Calibre crashed while adding books and now it wont launch at all. Both times the app crash faulting module was sqlite_custom_pyd.
I'm not sure if the problem is with the updated version or whether something I was adding corrupted the database or something. Any help would be awesome. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 45,646
There weren't any changes that could affect the database in 0.8.12. Run calibre ina command prompt as
calibre-debug -g and post the detailed error (if any) you get there. Also try a clean install, i.e. uninstall, delete c:\program files\calibre2 and then re-install. Doing so will not affect your books/settings. |
#3 | |
Device: iPod
I'll do the fresh install now and post back as soon as I've done it. |
If the re-install doesn't work, attach the metadata.db file from your calibre library folder.
Device: iPod
The reinstall didn't work. Here's the meta db from my library. I appreciate your help.
AS a workaround just delete sqlite_custom.pyd from your calibre install folder. I'll investigate the cause of the crash later.
Device: iPod
I deleted sqlite_custom.pyd and calibre played nice.
The crash is caused by a bug triggered by having more than 100 authors for a book, which in your case happens for Maori and Settler. Fix will be in next release.
Device: iPod
Wow, I am so impressed! Thank you so much for your help and being so quick!
You're welcome
| Calibre 0.7.36 crash | Phoul | Calibre | 5 | 01-02-2011 07:43 PM |
| Preferences causes Calibre to crash | PKFFW | Calibre | 2 | 06-07-2010 07:01 PM |
| Calibre 0.6.51 Preferences crash | GexMax | Calibre | 0 | 05-02-2010 10:04 AM |
| Conversions crash calibre | slantybard | Calibre | 0 | 07-20-2009 01:50 AM |
| HELP! Please Please Please! (Calibre Database Crash) | Abisha | Calibre | 7 | 06-10-2009 11:54 PM |
