Go Back   MobileRead Forums > E-Book Readers > Android Devices > enTourage eDGe > enTourage Archive
Old 04-01-2011, 02:58 AM   #31
guyjack
Edge User
Originally Posted by Adiposius Maximus View Post
Angry Birds Rio refuses to install from the Amazon App Store...hmmmmmm.
installed on mine...but runs very slow
Old 04-01-2011, 12:48 PM   #32
kenjennings
Edge User
Yes, I have all three of those free Angry Birds games installed. They all run slow. Animation is 1 frame per second. Maybe 1.5.
It can't be just screen resolution that restrains performance so much. While the physical screen is physically larger than most displays, the actual pixel count isn't that much more than the larger phones.
Old 04-01-2011, 02:40 PM   #33
Donny
Edge User
Hey gang!
Been a lurker until now, but like you happy users of a Pocket Edge, sad to hear some of the news here.
I am hoping you can help with a question: I am gussing many of you are using the EE, not the Pocket. Is the Ermine beta okay to use on the Pocket or is it EE specific?
Thanks!
Old 04-01-2011, 02:46 PM   #34
borisb
Edge User
It's available for both, Donny.
Old 04-01-2011, 02:53 PM   #35
glen
Edge User
Originally Posted by Donny View Post
Hey gang!
Thanks!
There is a thread in the Ermine subform on experiences with the beta for gothh devices.
So far there are a couple issues, but right now I am still liking the beta.
Old 04-01-2011, 04:54 PM   #36
Kynareth
Edge User
I'm just updating to Ermine and I'm really thankful to Entourage for this BETA update !
One question. What means : Apps Tray – no longer swipe up, just tap ?
Old 04-01-2011, 04:56 PM   #37
borisb
Edge User
At the bottom of the LCD side is a stylized "X" which you currently need to drag upwards to reveal all the apps installed. Now, I guess, you just tap on the "X" icond to get the application list.
Old 04-01-2011, 06:30 PM   #38
glen
Edge User
Even without the beta boris is on top of things :P
It now functions more like a separate window rather than a "tray".
Old 04-01-2011, 08:42 PM   #39
Donny
Edge User
Thanks Boris. Now if I can just find it. I see nowhere to opt in to anything beta. then again it doesn't show my device as registered either.
Old 04-01-2011, 08:58 PM   #40
borisb
Edge User
You may find it easier to use your eDGe. Run the Store app and click the "My Account" link at the bottom of the page. You may need to log in first, but then you'll see the beta message on your eDGe.
Old 04-01-2011, 09:58 PM   #41
Donny
Edge User
Apparently I have two accounts at the store. Once I got the right email I was good. Consider it downloaded and running pretty smoothly!
Thanks!
Old 04-01-2011, 11:05 PM   #42
mobius
Edge User
I installed Ermine on my EE but am not able to install any aps from amazon market place. Any suggestions?
Old 04-01-2011, 11:06 PM   #43
borisb
Edge User
What message are you seeing?
Old 04-01-2011, 11:36 PM   #44
mobius
Edge User
It just gives the message that application not installed. No specific error message. Is there a way to see the logs?
Old 04-01-2011, 11:39 PM   #45
borisb
Edge User
I don't know about logs. It could be the app needs a bit of hardware the eDGe doesn't have, like GPS or an accelerometer. You can try shutting down the eDGe and booting back up and try again to see if that works...
PE back from hospital, should I try Ermine again? AbbyNormal enTourage eDGe 11 06-09-2011 02:13 PM
Ermine Hibernation issues mrlanrat enTourage eDGe 11 05-28-2011 12:22 AM
How to get Ermine on PE after registration Readerirv enTourage eDGe 1 05-22-2011 04:01 PM
Ermine/Froyo vs calibre Gunnerp245 enTourage eDGe 6 04-12-2011 11:00 PM
Ermine win/lose? Augaire enTourage eDGe 6 04-05-2011 08:55 PM
