Go Back   MobileRead Forums > E-Book Software > Calibre > Recipes
Old 11-21-2010, 06:19 PM   #1
mufc
mufc doesn't littermufc doesn't litter
Device: Sony 650
Remove color behind hyperlink
I have great success creating my own or modifying other recipes for best readability of my sony ereader. One thing I wanted to do and did was remove the hyperlink properties using
a {text-decoration: none; color: black;}
a [href] {text-decoration: none; color: black;}
I have tried but failed to remove the highlight background from the hyperlinks.
They highlighted background does not show up when reading in Calibre but does when reading on my ereader. Am I correct in assuming that I need to change something in the css of epub output ? If so where is this file and what is it called ?
mufc is offline   Reply With Quote
Old 11-21-2010, 10:33 PM   #2
you can't change that in css. To change that you have to use preprocess_html and change a tags to span tags
Old 11-22-2010, 05:57 AM   #3
marbs
marbs began at the beginning.
Device: nook
if you do not want the link at all you could use remove_attrs to remove the href attribute
marbs is offline   Reply With Quote
Old 11-23-2010, 02:51 PM   #4
kiklop74
kiklop74 can program the VCR without an owner's manual.kiklop74 can program the VCR without an owner's manual.kiklop74 can program the VCR without an owner's manual.kiklop74 can program the VCR without an owner's manual.kiklop74 can program the VCR without an owner's manual.kiklop74 can program the VCR without an owner's manual.kiklop74 can program the VCR without an owner's manual.kiklop74 can program the VCR without an owner's manual.kiklop74 can program the VCR without an owner's manual.kiklop74 can program the VCR without an owner's manual.kiklop74 can program the VCR without an owner's manual.
kiklop74's Avatar
Device: Kindle Voyage
This is what I recommend for link cleanup:
    def preprocess_html(self, soup):
        for alink in soup.findAll('a'):
            if alink.string is not None:
               tstr = alink.string
               alink.replaceWith(tstr)
        return soup
This converts all links to text (less tags means safer rendering)
kiklop74 is offline   Reply With Quote
Old 11-24-2010, 08:56 AM   #5
mufc
Device: Sony 650
removed
Hyperlink adachim Kobo Reader 0 11-02-2010 11:57 PM
will kindle dx help publishers see they need to hyperlink textbooks? med007 Amazon Kindle 8 10-16-2010 05:08 PM
Is a hyperlink editor in sight? HarryT Sigil 2 08-12-2010 09:18 AM
Hyperlink? fcoulter Sigil 3 03-28-2010 11:31 AM
RFE: Remove remove tags in bulk edit magphil Calibre 0 08-11-2009 11:37 AM
