Go Back   MobileRead Forums > E-Book Readers > More E-Book Readers > iRex > iRex Developer's Corner
Old 11-18-2007, 09:08 PM   #1
joblack
joblack ought to be getting tired of karma fortunes by now.joblack ought to be getting tired of karma fortunes by now.joblack ought to be getting tired of karma fortunes by now.joblack ought to be getting tired of karma fortunes by now.joblack ought to be getting tired of karma fortunes by now.joblack ought to be getting tired of karma fortunes by now.joblack ought to be getting tired of karma fortunes by now.joblack ought to be getting tired of karma fortunes by now.joblack ought to be getting tired of karma fortunes by now.joblack ought to be getting tired of karma fortunes by now.joblack ought to be getting tired of karma fortunes by now.
Device: Onyx Boox Tab X C
Aircrack-ng for iLiad
Does Aircrack NG work for the iLiad? Which network card is installed? Is the CPU strong enough to search for the key?
joblack is offline   Reply With Quote
Old 11-22-2007, 08:55 AM   #2
kurifu
kurifu began at the beginning.
Device: iLiad
CPU might run a little slow for this sort of thing, though may not be a problem depending on the strength of the network, and the number of weak samples you come across, the bigger two issues are
1) Only certain network cards support the PEEK call which allows aircrack to work, Orinico and Prism cards are generally the ones that work, also Aetheros, I don't know what is in the iliad, but somehow I doubt it is one of those.
2) Now I generally don't follow up to much on how aircrack works, but last I checked (when WEP cracking first came about) it required a fair amount of disk space to store the encrypted messages, which generally is a bit of an issue on the Iliad.
kurifu is offline   Reply With Quote
Old 11-23-2007, 06:40 AM   #3
joblack
You need around 800 - 1100 MByte free space. The actual sniffing doesn´t take so much processor speed. The actual cracking was around 4 minutes (3,6 GHZ Celeron) - the iLiad should need more time for that.
Old 11-25-2007, 12:52 AM   #4
kurifu
Device: iLiad
Yes, depending on the type of attack you are using against the wireless network.
However, even with those possible limitations aside, we come to another problem.
Currently aircrack-ng does not provide support for the MRVL_CF8385 wireless card (module cf8385), I could not find any patched version of this driver either which allow you to peek, or inject packets. I am not sure if it is possible (though I imagine it is), but this will have to be overcome before aircrack-ng will work.
Other tools like airsnort and kismet have even greater limitations, supporting typically Aetheros, Prism and Orinico cards only.
iliad-regutils: Easy editing of the iLiad registry Martijn iRex 7 09-04-2010 06:12 AM
POLL to Iliad owners: Should people buy an Iliad or not? ali iRex 20 01-20-2010 06:11 AM
iLiad How to make iliad into a SSH server and connect with iLiad tudou331100 iRex Developer's Corner 21 02-06-2009 05:35 AM
Ended Iliad iRex + Iliad cover for sale in London acorral Flea Market 0 01-16-2009 06:09 AM
iLiad Book Edition slower than iLiad v2: different sw version? SecondoMe iRex 17 05-14-2008 01:42 PM
