Old 02-20-2014, 12:04 PM   #646
brinkop
brinkop began at the beginning.
Device: kindle fire hd
ahhh okey do you got a link for me to the right Forum for my Problem
brinkop is offline   Reply With Quote
Old 02-20-2014, 06:44 PM   #647
Ex-Helpdesk Addict
Device: No PW2, KV, KOA
Start here:
http://www.mobileread.com/forums/index.php
Old 03-01-2014, 04:11 AM   #648
pattision
pattision began at the beginning.
Device: kindle4
Thanks very much for your software! Just registered an account to thank you
It's so convient for lazy ones like me, who don't want to learn about all those jailbreak things and just want to enjoy the reading as soon as possible.
Actually I didn't mean to unbrick or jailbreak my kindle4, it was just running too slowly, so I used your software to recover it. It turns out very useful.(Although I sacrificed an U-disk for it...)
pattision is offline   Reply With Quote
Old 03-01-2014, 08:40 AM   #649
Old 03-15-2014, 07:08 AM   #650
hongxue
hongxue began at the beginning.
Device: kindle touch
Smile sorry to disturb
hi.thank you for your tool.i come from china,so my english is poor,sorry.
i have a problem while using this tool.my kindle touch stop working in about two months ago,and i tried a lot of methods to make it work but failed.
it seems like this:the led light keeps orange when i connect it to pc or a charger.and it never turns green,no matter how long.i tried to open it and get the battery charge by a phone charger.about three hours later,it showed that the kindle is full,but i tried to use kubrick,and failed again.the screen showed that message of "waiting for device" when flashing diags or something. it kept red and never turned green,so i cannot move on.i run the tool in usb stick.
i not sure if i make it clear,but i really hope that you can help me .thank you so much!
hongxue is offline   Reply With Quote
Old 03-18-2014, 08:01 PM   #651
kayalemao
kayalemao began at the beginning.
Device: Kindle 4
Smile
Thank you so much. It worked without any problems and now my Kindle is back to use.
kayalemao is offline   Reply With Quote
Old 03-21-2014, 01:26 PM   #652
dito
dito began at the beginning.
Device: Kindle Keyboard 3G
I've had the same problem and so hase my friend. I have not found any solution for this, but I'm afraid it seems like a hardware failure
dito is offline   Reply With Quote
Old 03-31-2014, 12:29 AM   #653
Iznogold
Iznogold began at the beginning.
Device: kindle 3.2.1 wifi
it stucks at 0% at the "flashing main partition" screen. any ideas?
Iznogold is offline   Reply With Quote
Old 04-01-2014, 03:58 AM   #654
romsik
romsik began at the beginning.
Problem is solved... Sorry for post )
romsik is offline   Reply With Quote
Old 04-01-2014, 05:50 PM   #655
erwichii
erwichii began at the beginning.
Device: kindle
WOW!!!!!!! I have my kindle dead by like 1 or 2 years ago... I left in that way because I dont understand the method for flashing it, but with kubrick I give it a new life!!!! thanks to the team who made this possible, and now Im reading how to donate to the project you support.
Many Thanks!!!!
erwichii is offline   Reply With Quote
Old 04-25-2014, 06:34 AM   #656
linlum
linlum began at the beginning.
Device: Kindle3wifi,Kindle Touch
Question I have debrick my kindle3w by this Kubrick tool.
I am from China. Sorry my poor english .
Thank you very much ,ixtab !
But I have a problem ,I couldn't install "update_usbnetwork_0.53.N_k3w_install.bin".It noticed "update failure."
kernel version is 3.4. May I install an old version for usbnetwork?
Where can I find history version of usbnetwork for k3w ?
Thanks again!
linlum is offline   Reply With Quote
Old 04-25-2014, 11:54 AM   #657
eschwartz
Ex-Helpdesk Junkie
eschwartz's Avatar
Deleted.
Last edited by eschwartz; 04-25-2014 at 11:57 AM. Reason: K3 always includes the jailbreak. :o
Old 04-25-2014, 01:18 PM   #658
Ex-Helpdesk Addict
Deleted.
I can answer this one (its within my pay grade):
No Comment.
Old 05-01-2014, 05:17 AM   #659
linlum
I solved it !
I solved it !
First perform uninstalling by using "update_usbnetwork_0.54(or 0.53).N_k3w_uninstall.bin",then install 0.54 version.
Thanks again!
Old 05-02-2014, 05:27 AM   #660
shurikh
shurikh began at the beginning.
I did test it few times on my bricked KT. Works great! Thank you very much!
shurikh is offline   Reply With Quote
Use regular DX(i) to debrick a DXG craziskata Kindle Developer's Corner 10 07-16-2013 09:10 AM
DX(G) How to debrick a demo DXG? xcomme Kindle Developer's Corner 0 02-14-2013 04:06 PM
K3 Trying to debrick, but connection keeps dropping Zolyx Kindle Developer's Corner 6 12-10-2012 08:04 AM
Help to Unbrick KT with simple debrick Method. Loko_bielsa Kindle Developer's Corner 2 07-16-2012 08:26 AM
A easy and offical way to debrick k3. xueyou2 Kindle Developer's Corner 3 05-01-2012 09:42 AM
