Old 05-31-2013, 06:32 AM   #421
akikara
akikara began at the beginning.
You mean put file to main directory then update my kindle thing? It look like works but I tried to install Usbnetwork hack. updated my kindle, restarted device but unable to connect anyway from my ubuntu : (
akikara is offline   Reply With Quote
Old 05-31-2013, 08:21 AM   #422
Helpdesk Junkie
Device: Too many.
Now follow the directions included with the USB networking to enable it.
Old 06-01-2013, 05:54 AM   #423
ebooksfans
ebooksfans is faster than slow light.ebooksfans is faster than slow light.ebooksfans is faster than slow light.ebooksfans is faster than slow light.ebooksfans is faster than slow light.ebooksfans is faster than slow light.ebooksfans is faster than slow light.ebooksfans is faster than slow light.ebooksfans is faster than slow light.ebooksfans is faster than slow light.ebooksfans is faster than slow light.
Device: kindle 3
boot kubrick from harddisk use grub4dos
1.grub4dos http://code.google.com/p/grub4dos-ch...downloads/list
2.save kubrick live cd as kubrick.iso
3.use grub to boot kubrick iso
map --mem /kubrick.iso (hd32)
map --rehook
root (hd32)
chainloader
4.fdisk -l
find disk and partion where you save kubrick.iso
5.mount
mount -t fat32 /dev/sdax /media/usbdisk
mount -o loop /mnt/usbdisk/kubirck.iso /media/cdrom
mount -o loop -t squashfs /media/cdrom/kubrick/JAVA.SFS /mnt/java
6.
sh autostart.sh
debian can be install from harddisk.
can autostart.sh add the function to search kubrick.iso and mount it.
ebooksfans is offline   Reply With Quote
Old 06-07-2013, 08:19 AM   #424
shurikh
shurikh began at the beginning.
Device: kindle touch
Look, I did it as well, but downgraded to 5.2.1, because even after jailbreak can't remove ads and lot of application works well on 5.2.1 and not works on 5.3.2.1
shurikh is offline   Reply With Quote
Old 06-11-2013, 08:33 AM   #425
shadowfang
shadowfang began at the beginning.
I can't succeed with Kubrik on my problem Kindle Touch.
It shows flashing the diags partition and never proceed forward. I tried several times and waited for it several minutes but with no luck.
Any advice how to diagnose why it doesn't proceed?
The problem with my Kindle Touch is the following:
Sometimes it is hanging and the screen freezes to the last image shown. It is in some busy loop as it slowly drains the battery. I can't even fix it with a restart except in a few cases.
The freeze usually happens after the screen was locked ( by screen saver, connected with USB to computer ) but once even on page turn.
Usually taking the battery restarts it and I can work with it but not every time. Some restarts are not successful.
I hope this is a software issue, but it behaves too strange and maybe a hardware.
shadowfang is offline   Reply With Quote
Old 06-11-2013, 09:04 AM   #426
Helpdesk Junkie
Device: Too many.
Note: The screen is **always** "frozen to the last image shown" - -
That is how e-ink works, it is "off" all of the time except when changing the display.
Sounds very much like a worn out battery.
Time for a new one.
Old 06-11-2013, 09:24 AM   #427
shadowfang
I think it is not the battery, as it keeps a stable voltage when I take it off the device and measure it. And the problem is happening even at nearly full battery ( above 4V)
Old 06-11-2013, 10:10 AM   #428
Helpdesk Junkie
Device: Too many.
Open terminal voltage of a Li-Ion battery is no indication of its storage capacity.
Old 06-11-2013, 11:39 AM   #429
shadowfang
Yes I know voltage is no indication of storage capacity but I don't have other method to measure the battery. And unfortunately doesn't have a spare one so I could test if replacement will help. Shipping costs to my country will take more than the price of the battery itself.
And it is strange to die after only a year of use.
Old 06-12-2013, 10:38 AM   #430
hawhill
hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.
hawhill's Avatar
Device: Kindle Paperwhite, Kobo Mini
Well, does it freeze when the document partition is empty? Maybe you have a faulty document lying around which makes the indexer go boom or something like that.
hawhill is offline   Reply With Quote
Old 06-12-2013, 11:39 AM   #431
shadowfang
I tried to remove all content and put it back with calibre. But I think I haven't made tests without books. I'll check when I succeed to boot. I've tried couple of times in the recent days but it fails.
Old 06-13-2013, 11:35 AM   #432
prosty
prosty began at the beginning.
Device: kindle 4
Guys, I am at the point where my kindle 4 should go into diagnostic mode. Boy under the tree disappeared, screen flashed and now I only have half of the screen black, half white. What happened?
This is how it looks like:
prosty is offline   Reply With Quote
Old 06-13-2013, 02:43 PM   #433
Helpdesk Junkie
Device: Too many.
You spilled your e-ink ?
Old 06-13-2013, 02:48 PM   #434
prosty
Device: kindle 4
Nope. The screen was 100% fine, and I think it still is (I can restart it, it blinks and sets itself to this thing in my lastpost). While flashing the kindle was laying on the table, this appeared when the supposed diagnostic mode was supposed to.
Old 06-13-2013, 02:52 PM   #435
Helpdesk Junkie
Device: Too many.
It still is - that is just an image that does not match the display setup.
My comment was due to the lack of details in what you did to reach this state.
If using KUBRICK (the thread you are posting in) that should never have happened.
So speak up - tell us exactly what you have done - a bit more than "its broke" please.
Use regular DX(i) to debrick a DXG craziskata Kindle Developer's Corner 10 07-16-2013 09:10 AM
DX(G) How to debrick a demo DXG? xcomme Kindle Developer's Corner 0 02-14-2013 04:06 PM
K3 Trying to debrick, but connection keeps dropping Zolyx Kindle Developer's Corner 6 12-10-2012 08:04 AM
Help to Unbrick KT with simple debrick Method. Loko_bielsa Kindle Developer's Corner 2 07-16-2012 08:26 AM
A easy and offical way to debrick k3. xueyou2 Kindle Developer's Corner 3 05-01-2012 09:42 AM
