Old 03-27-2013, 06:13 AM   #256
Welll I have rebooted more times than you can shake a stick at
Let me go check I have the files..
Hmm? where do they live again? DOH! lol
EDIT: Okay mine might have been missing? Okay... they were missing... Dunno why though.
So I restored them from a backup
Ill try again
Does another restart...
Old 03-27-2013, 06:21 AM   #257
yep. works fine now.
thanks
Old 03-27-2013, 12:51 PM   #258
Version 3.3
Version 3.3 released. It includes a bugfix for situations where the main partition is not to be flashed, but only some other actions (jailbreak, TTS...) are to be performed.
@twobob, dsmid: Sorry for the many updates lately - but now it should really be bug-free...
Old 03-27-2013, 12:54 PM   #259
Originally Posted by techiemonkey View Post
I chose jailbreak and default tts files in kubrick and then succesfully updated to 5.3.2 but whenever I enable text to speech, an error box pops up showing something like: text to speech has encountered an error.
OK, so I just tried this again.
- deleted TTS folder, then performed update to 5.3.2. (the order shouldn't really matter though).
- tried TTS, got error as expected.
- used Kubrick (version 3.3!), skipped flashing the main partition, but only let it reinstall the TTS files.
- result: 5.3.2 with working TTS.
Old 03-27-2013, 01:10 PM   #260
sweet.
Ill do my thing
EDIT: DONE
Old 03-27-2013, 10:38 PM   #261
dito
dito began at the beginning.
Device: Kindle Keyboard 3G
I have just burned the iso to CD and ran the thing and after a bit of loading it says that it cannot boot because its missing some java files :S
What should I do?
dito is offline   Reply With Quote
Old 03-27-2013, 10:41 PM   #262
What should I do?
First: double-check that you're using version 3.3. (i.e., re-download from the primary site if in doubt)
If the problem persists, please post the exact messages you're seeing (or, probably easier: photos of the screen, see a few posts back for examples).
Old 03-28-2013, 05:53 AM   #263
dito
Heres the pic http://puu.sh/2ppIH
Also, this may not have anything to do with this problem but maybe its remotely connected : when I type shutdown in the console on this pic it doesnt go to shutdown, it does not recognize the command
Old 03-28-2013, 06:18 AM   #264
Thanks for the picture!
It unfortunately seems like you are using a CD or DVD drive which is not supported by Kubrick (or, more specifically, by the Kernel used). Can you give some more information about your configuration? I.e., what CD or DVD drive is it (exact make and model), how is it "attached" to the system (IDE, USB, S-ATA...), etc. ?
In case you're confused: note that saying "the drive is not supported" while the system clearly booted from it is not a contradiction. Your BIOS managed to detect the device and load the initial ramdisk, but the Linux kernel doesn't seem to recognize your drive. This is why it's important to know as much information as possible about the drive - maybe I missed some kernel configuration options, or maybe it really isn't supported. In any case, your input would be very helpful.
That said... I guess that your only option for now is to either try on a different computer, or - if you have a USB stick to spare and your computer can boot from USB - to try with a USB stick.
Regarding "shutdown": yeah, my bad. The correct command is "poweroff"
Thanks for pointing it out - I'll fix it in the next version (which will hopefully also support your CD drive... if possible).
Old 03-28-2013, 07:01 AM   #265
dito
Im surprised that my dvd drive isn't supported because I bought it as a best buy.
The device is PIONEER DVD-RW DVR-115D ATA Device
Old 03-28-2013, 07:26 AM   #266
http://www.pioneer.eu/eur/products/a...15D/media.html
firmware update applied?
Old 03-28-2013, 07:33 AM   #267
Hmm... That's not exactly terribly exotic, and not terribly new, either. So it should have been recognized
Just to be sure, could you boot once again, and run "cat /proc/sys/dev/cdrom/info", please?
@all Linux experts: Since this seems to be a plain ATAPI device, what could I possibly have done wrong in the kernel configuration to cause this drive not to be detected?
uname -a
Linux kubrick 3.7.10-kubrick #6 SMP Tue Mar 12 11:59:55 UTC 2013 i686 unknown
# /proc/config.gz attached to this post
Any help is really appreciated...
Old 03-28-2013, 08:17 AM   #268
hawhill
hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.hawhill ought to be getting tired of karma fortunes by now.
hawhill's Avatar
Device: Kindle Paperwhite, Kobo Mini
Well, there are _lots_ of PATA controller drivers you didn't enable... (CONFIG_PATA_*) And the PATA_LEGACY is also disabled. Since the times of libata, that ought to be the main difference between PATA and SATA paths.
hawhill is offline   Reply With Quote
Old 03-28-2013, 08:41 AM   #269
dito
http://puu.sh/2psiI
I installed the new firmware right now
Ill report after i see if things changed
EDIT: nope, still not working
Old 03-28-2013, 09:13 AM   #270
Whoops. If you say so - well, you're most probably right .*
I tend to get lost in "make menuconfig", because it seems like everything depends on everything else, 5 menu levels away... and I started from the vanilla kernel configuration.
So yeah, any help is really welcome. I *guess* that the only part which needs tweaking is really CD-ROM support - should be "support everything". All the rest is just candy, but I want to keep it as small as possible (except for the required stuff like squashfs etc.)
So if anybody with more experience could post a "recommended" configuration, I'd be more than grateful.
(*)Hmmm... IIRC, the kernel configuration itself said to "disable in favor of the new libata (or so)" - should I still enable it?
Use regular DX(i) to debrick a DXG craziskata Kindle Developer's Corner 10 07-16-2013 09:10 AM
DX(G) How to debrick a demo DXG? xcomme Kindle Developer's Corner 0 02-14-2013 04:06 PM
K3 Trying to debrick, but connection keeps dropping Zolyx Kindle Developer's Corner 6 12-10-2012 08:04 AM
Help to Unbrick KT with simple debrick Method. Loko_bielsa Kindle Developer's Corner 2 07-16-2012 08:26 AM
A easy and offical way to debrick k3. xueyou2 Kindle Developer's Corner 3 05-01-2012 09:42 AM
