Old 03-15-2013, 08:10 AM   #181
O-Tello
O-Tello began at the beginning.
Device: Kindle 4NT
Just to make sure I understood the instructions correctly. Kindle 4NT. When speaking about the 5-way down button you mean the "big" button in the middle of the Kindle. And "down" means the side that is pointing towards the "end" of the Kindle (where the power button is)?
O-Tello is offline   Reply With Quote
Old 03-15-2013, 09:13 AM   #182
elbirch86
elbirch86 can extract oil from cheeseelbirch86 can extract oil from cheeseelbirch86 can extract oil from cheeseelbirch86 can extract oil from cheeseelbirch86 can extract oil from cheeseelbirch86 can extract oil from cheeseelbirch86 can extract oil from cheeseelbirch86 can extract oil from cheese
Device: Kindle 4 Black
Ok, i have tried again today to boot from CD Rom but got the same as when tried wit Dvd come up saying
Boot from CD:
Not boot device available, press enter to retry
Sata-0: Installed
Sata 1: Installed
Sata 4: Installed
Sata 5: None
With the Usb stick i just got Boot error
any help would be appreciated thank you
elbirch86 is offline   Reply With Quote
Old 03-15-2013, 09:28 AM   #183
Device: No PW2, KV, KOA
That depends on the PC you are trying to boot with the CD/DVD -
And you included no information about your PC or the settings of its BIOS.
Translation: Impossible to answer.
knc1 is online now   Reply With Quote
Old 03-15-2013, 10:34 AM   #184
elbirch86
Hi sorry its Dell PC running Windows Vista bios is set to boot from hard disk, but changed it to boot from CD Rom when trying to boot
Old 03-15-2013, 11:06 AM   #185
Hmmm... That is odd.
I can't think of a single good reason.
Old 03-15-2013, 04:50 PM   #186
O-Tello
Device: Kindle 4NT
Anybody who can help? Seriously, I feel like an idiot asking that. But I cannot access the USB downloader mode. Am I doing anything wrong? I follow exactly the steps that are listed in Kubrick. Is there a specific amount of time I have to wait for each step when activating USB downloader mode? Is there anything I did not recognize? Any help is gladly appreciated!
Old 03-15-2013, 05:04 PM   #187
Yes, the DOWN button is the button at the bottom of the 5-way controller ("south" button, if that makes more sense). Make sure that you are following the instructions *exactly*, i.e.
- press and hold the power button until the LED turns off.
- keep the power button pressed, and in addition, press the "down" button.
- release the power button.
- release the "down" button.
Unless your Kindle has some kind of hardware defect (like the down button not working at all), this *does* work, and *will* put the device into USB downloader mode.
Old 03-15-2013, 05:11 PM   #188
O-Tello
Device: Kindle 4NT
Thx for verifying! I do exactly as written by you. But Kubrick doesn't give me any feedback. It's waiting for the device and nothings happening anymore... But I keep on trying and keep my fingers crossed that the problem is in front of the computer. :-)
Old 03-15-2013, 06:34 PM   #189
O-Tello
Device: Kindle 4NT
It worked. Problem was the computer... For some reason it didn't recognized the Kindle properly. I tried it with another machine. It worked without any problem. Thx so much for your support!
Old 03-17-2013, 12:41 PM   #190
wolfdingo
wolfdingo began at the beginning.
Device: kindle 5
flashed.... but repair need again
kubrick is really helpful, useful and convenient tool.
But... After debricking (kubrick wrote that kindle NT is debricked) Kindle started to reload and error message about Repair.
What is wrong and how it can be cured?
wolfdingo is offline   Reply With Quote
Old 03-17-2013, 05:20 PM   #191
Err... more need a bit more information than you have provided to "guess"
Did you mangle the FAT system files? Isn't there like 2 extra options to cover such eventualities?
Did you try them?
Old 03-17-2013, 08:27 PM   #192
Zero the re-try counter in /var/local
Old 03-18-2013, 05:39 AM   #193
Select the option to delete the internal partition in Kubrick - this will lose all settings (but not the documents).
Or, if you're an advanced user, you can SSH in (while in diags) and delete the /var/local/upstart/lab126_gui.restarts file, as knc1 suggested. The next version of Kubrick will do that automatically, but that version isn't ready yet.
EDIT: /var/local/upstart/lab126_gui.restarts is for the Kindle Touch - the correct file on the K4 is /var/local/system/.framework_reboots.
Old 03-18-2013, 02:48 PM   #194
wolfdingo
Device: kindle 5
problem solved
thanks, this helps. ixtab, do you accept donation? I believe your efforts and advises should be rewarded.
Old 03-18-2013, 03:54 PM   #195
Thank you very much for the appreciation!
Yes, I used to accept donations. And I have used some of them to "stock up" my Kindle inventory (so thanks again to everybody who donated!)
At this time, I'm forwarding all donations to a literacy project in Laos (which is why my website is also pointing there).
Long story short: Yes, please DO donate - but don't give your money to me personally. Give it to a project that is so much more important than I am, and where every single donation - even 2 $ - actually does make a change for the better:
Big Brother Mouse - A book for every child
Full disclosure: No, I'm not affiliated in any way with Big Brother Mouse or the Laos Literacy Project. I'm simply a guy who, while spending some time in Laos, fell in love with the people there. And I know that every single dollar invested in education there is worth it, and will bring happiness to many more people than just myself.
Please do donate if you find Kubrick helpful. And visit Laos if you get the chance - it's a beautiful country with wonderful people.
