Old 12-03-2012, 06:47 AM   #1
KWhytte
KWhytte began at the beginning.
Device: None
Question catalogue builder output columns are not in the same order in the output
I'd like to get a csv output first:
1) Why create catalog button clicked and options title/author/size picked in that order gives author/size/title columns in csv
2) Why very few of the titles not sorted by title alphabetical order (yes I sorted them in alpabetical title order in calibre (Yes they are sorted OK in Calibre view)
(I don't know if you have another way of doing this output, if so , please show me how:
After getting the csv file I open it with comma and quotation mark ticked and save as xls and html to view it either from my desktop or web copy to check and see if I have that particular book or what I have with specific author etc.
If you know another way to create such htm output from the books listed in my calibre without running the calibre please show me how: )
KWhytte is offline   Reply With Quote
Old 12-03-2012, 10:11 AM   #2
Device: Astak Pocket Pro, K4NT,Galaxy Tab 2
random Sort ordering is almost always caused by the corresponding xyz_sort field being RED in the Metadata editor.
The Quality Check PI can: Check Title sort, Check Author sort
and present a list so you can fix (Select All: Bulk Metadata edit: (there are tick boxes for each: Update Author Sort, Update Title sort)
Old 12-03-2012, 11:14 AM   #3
GRiker
Comparer of the Ephemeris
GRiker ought to be getting tired of karma fortunes by now.GRiker ought to be getting tired of karma fortunes by now.GRiker ought to be getting tired of karma fortunes by now.GRiker ought to be getting tired of karma fortunes by now.GRiker ought to be getting tired of karma fortunes by now.GRiker ought to be getting tired of karma fortunes by now.GRiker ought to be getting tired of karma fortunes by now.GRiker ought to be getting tired of karma fortunes by now.GRiker ought to be getting tired of karma fortunes by now.GRiker ought to be getting tired of karma fortunes by now.GRiker ought to be getting tired of karma fortunes by now.
Device: iPad
The CSV and XML output formats are intermediate formats, meaning that they are intended to be used as input to another program, for example a spreadsheet program. After importing the file, you can rearrange the columns and sort the contents in Excel as you choose.
It sounds like you have a particular workflow with Excel - why not create a macro?
You might also consider outputting your catalog in EPUB format and using the calibre reader to view it. You can create a catalog from the CLI, writing the output to your desktop, then open it from there. You can do all that without opening calibre's GUI.
G
GRiker is offline   Reply With Quote
Old 12-03-2012, 11:36 AM   #4
KWhytte
Device: None
Let me see if I could do that.
Just for a reminder: A to Z listing shows up with no problem within the calibre interface.
The listing then changes in the csv output.
Old 12-03-2012, 11:43 AM   #5
KWhytte
Device: None
G
As I briefly mentioned I get the csv output first then check comma and quotation mark while opening it in excel, then save it as htm output.
I did try epub and mobi outputs which gave me around 11mb file to handle while the htm output I often refer to is only 0.6mb and keep it open often to check/search or refer to in my collection of over 4000 items in calibre (not all of them books, some are university thesis) Not to mention I also upload a copy to the net as htm file for easy access from everywhere. I often update these files once a week too depending how many additional items added to my calibre
So the speed to open as well as small footprint to keep it on is crucial for me
Old 12-04-2012, 02:03 AM   #6
KWhytte
Device: None
Thank you theducks
Thank you GRiker
I appreciate your explanations very much.
theducks: I am afraid I am not very competent to do such sorting in Calibre.
Maybe a better component or ad on could be included in the upcoming versions of Calibre
Sorting in excel sound like the easiest way around I think.
(I did not know how as I was using not the MS Excel)
I managed to do it just now.
So if there's a way I could get the output from calibre, I'd like to hear about it.
Combined output (0.8.65) alanHd Calibre 3 08-18-2012 12:43 AM
Author/Title order in mobi output file macnab69 Conversion 5 01-25-2012 01:20 AM
Columns in pdf output kenoli Conversion 1 09-04-2011 01:31 AM
EPUB output kovidgoyal Calibre 920 02-05-2011 11:59 AM
What output profile should I use? Autarch1 Calibre 2 11-02-2009 03:17 AM
