Old 09-06-2012, 08:00 AM   #1
Rolfy
Rolfy began at the beginning.
Device: Sigil
Converting to html needed?
Hi. Instructions says I need to convert word-documents into html. So I did, and could not use Book view.
In a blog I was advised to paste my document right into an empty new Sigildocument. This seems to work. When I check changes made in the Book view I note changes in the html code as well.
So, I do not need to convert? Pasting text is all needed?
Regards from Stockholm
Rolfy is offline   Reply With Quote
Old 09-06-2012, 08:32 AM   #2
Toxaris
Toxaris's Avatar
Device: PRS-300, PRS-T1
By copy/pasting you will loose formatting. That includes italic and other, not to mention things like footnotes, indents and so on. Styles, headers, etc all is lost.
You can prevent that by converting Word to HTML. There are several methods for that, most of them not good. Expect some manual cleaning up.
Old 09-06-2012, 09:01 AM   #3
mncowboy
Wanderer
mncowboy ought to be getting tired of karma fortunes by now.mncowboy ought to be getting tired of karma fortunes by now.mncowboy ought to be getting tired of karma fortunes by now.mncowboy ought to be getting tired of karma fortunes by now.mncowboy ought to be getting tired of karma fortunes by now.mncowboy ought to be getting tired of karma fortunes by now.mncowboy ought to be getting tired of karma fortunes by now.mncowboy ought to be getting tired of karma fortunes by now.mncowboy ought to be getting tired of karma fortunes by now.mncowboy ought to be getting tired of karma fortunes by now.mncowboy ought to be getting tired of karma fortunes by now.
mncowboy's Avatar
Device: Kindle 3, PaperWhite 2
If you use styles for everything in the Word document, it will work well.
Then save as a filtered web page.
Add the file to Sigil.
Delete everything between the style and /style - should save several hundred lines.
Enter link for the external stylesheet that matches the styles in the Word doc.
Add the style sheet to Sigil.
You now have a clean document!
Bob
mncowboy is offline   Reply With Quote
Help needed - converting ePub to Kindle mobi format VRBurnett Conversion 3 02-26-2012 04:06 PM
Help needed in reading / converting rgo files evenstar120 Other formats 3 01-13-2012 12:21 AM
Help needed by A Newbie for converting .JAR files merseybeatle Reading and Management 1 12-08-2010 04:01 PM
Free Book Download! Help needed converting... eidolon5861 Deals, Freebies, and Resources (No Self-Promotion) 4 04-18-2009 11:29 PM
PRS-500 HTML merge tool needed sic Sony Reader Dev Corner 14 11-07-2007 06:04 PM
